bluebeard
What the#!^*#~## Good is search
I would like to know what good the search tool is if it never works. It seems to pull up everything but what you are searching for.. :ranting2:
Im searching for information on spirit dyes..
Can some one point the way.. Thank you
Go to the "Dyes, Antiques, etc" forum.
Put in your search terms, i.e. "dyes" or "spirit dyes".
I entered "spirit dyes" and came up with 3 pages of closely related posts.
No search engine is perfect, but this one is about as good as they get.
G'luck and have fun.
Well dahhhhhhh....everyone knows you can't dye a spirit.....
Seriously, go to the nav_m.gif Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners. forum, then search "spirit dye"...make sure you use the quote marks.....I got several related threads.
Your computer is your friend. It only does what you tell it to do, and in this case, the search function is doing only what you tell it to do.
Click 'search'
click 'more search options'
click 'advanced usage help'
This will bring up a small window that explains how to use the boolean operators, such as quote tags, asterisks, and plus signs.
A little practice, and you'll have it serving up exactly what you're looking for. Ya just gotta know how to ask nicely:)
...and Rayban, would dyeing spirits with spirit dye cause spirits to die? Oh, I have so much fun with spiel Czech.
Edited by TwinOaks
Thank you all and may the great spirit show you the way before you dye.....Or something like that.. :)
In my case, it certainly wouldn't hurt having the Great Spirit helping me out when I'm dyeing something...
Hi bluebeard,
you sent me a pm but my computer chucked a sad when I went to post it and I'm not sure if it sent the complete message. Anyhow if your also looking for suppliers of Spirit dye in Oz these places should be able to help.
Birdsall Leather http://www.birdsall-leather.com.au/ (NSW) make their own I use these not enough colours for what I want though
Crispin leather http://www.crispinleather.com.au/ (QLD) I think they make their own as well, Rod Stanger from Leatherwood uses these
Leffler Leather http://www.leffler.com.au/ (VIC) Sells Raven Oil
Toowoomba Saddlery http://www.ozsaddle.com/ (QLD) Sells Raven Oil
These are the main places I know of I also at times make my own from Rit Clothes Dye and Metholated spirits (original idea from Rod Stanger mainly for making blues and purples which are difficult to get here). here are the threads to check out regarding that process.
http://leatherworker.net/forum/index.php?s...pic=3924&hl
http://leatherworker.net/forum/index.php?s...pic=1423&hl
http://leatherworker.net/forum/index.php?s...pic=6864&hl
Hope this is of some help
Cheers,
Clair
When I'm doing a search that I want to use two words in such as spirit dye. I plug the words in witha positive sign before each word without any spaces for example +spirit+dye ... This may be common knowledge to most but I didn't know this until I stumbled onto it somewhere. I use to get as pissed off as you sound.
Good luck
James
Use quotation marks with your search you will get a more specifc search than a broader search return without them.
such as "Spirit Dye"
Tal~
