What would be a good average drying time between coats of dye and the final coat before the finish is applied?
Frank
Frank, what type of dye are you using?
Kate
I've been using Eco-Flo but just bought some Fiebing's. I'm new at all of this and I'm doing some comparisons.
Frank
Eco-dyes are water based, Fiebing's are alcohol based. As such they dry at drastically different rates. I like to let my dye coats mostly dry, as it shows where the streaks are. Since I switched to spraying the dye on with an airbrush, drying time is measured in seconds, with a light buffing with a dry cloth between coats (if more than one is needed) to remove excess solids. I've only had to do that once, though, because the spraying gives such even results.
The time between coats if you're applying with a sponge or dauber will vary with ambient conditions- temp., humidity, and airflow being the key ones.
For the final finish/sealer my preference is for the piece to be completely dry before application.
Edited by TwinOaks
