mclarke
Leather Suitcase
Can any of you leather pros give me an idea of what might be used to create the frame and ridged ness of this suite case - http://www.saddlebackleather.com/Classic-Suitcase?sc=8&category=1289
How is somewhat " light"? What is sandwiched between the pigskin and leather? Where can I buy supplies to recreate etc?
Any helps is appreciated
Thanks
Matt
Can any of you leather pros give me an idea of what might be used to create the frame and rigidness of this suite case - http://www.saddlebac...8&category=1289
If you have The art of Making Leather Cases by Al Stohlman, take a look at page 50. If you don't have it, it's probably time to get it. You can purchase the eBook from Tandy.
Use either 1/8" Masonite (hardboard) or 3 mm plywood paneling. Your local home centre should have them. You may be able to get off-cuts from a builder or smaller panels at the home centre.
Tom
Thanks Tom - I MIT have that book.. A going to take a look. How would you create the angles? Attempt to screw it together?
Thanks
Matt
It would all be stitched together, Masonite would just be the stiffener. Page 50 volume 2. The leather corners would be mitered and stitched.
David
