wlg190861
Mm X Inch Or Oz
I don't know if this is the right place but, I would like to know if there is somewhere I can get a conversion chart to convert metric to oz..
Like 2 to 2 1/2 MM = How many oz.. ?
Edited by wlg190861
Here's one I use...
post-5624-0-09845900-1393829563_thumb.jp
Edited by Tina
Sorry for wrong topic. I ment millimeters to oz..s
1oz = .4mm
Andrew
I think this ended up a wee bit wrong, should be:1 oz = 0.4mm :-)
This is the chart that I remember seeing before. After some quick searching, it looks like there are a few conversion charts that might contain some errors. Hopefully using more than one source helps increase your odds...
post-32478-0-13582700-1393830087_thumb.p
thank you all
Uh... You just wrote the same thing I did...
Andrew
Ahhh...I see the smaaaaall dot now, I need new glasses *S*
