horseplay
Straight Post On Custom Belt Buckle
I've been asked to make a plain belt for a custom buckle. Seems easy enough but the buckle has a straight post for the belt holes. All the buckles I've ever worn have a curve to the post so that it hooks into the belt hole and stays in place. With the straight post I'm concerned that the belt will easily come undone when the customer moves around. Any ideas?
Hmmmm. sounds to me like this is a conversation you should be having with the buckle owner. Is it possible to bend the post to make a curve in it? If it is a cast piece, can the post be filed, or ground to make it hook more. In any case, it is something for you and the buckle owner to work out.
