awharness
441 Stitch Length Lever Jumping/falling Out Of Reverse
When I have my 441 in reverse the lever falls down, and it will "hop" with each stitch. How do I tighten it up? I haven't even really tried to resolve this issue yet!
-Andrew
Take the plate off the back on the left hand side looking at the machine from the back. Turn the hand wheel till you see a screw, tighten it up just a little, the screw is hard to turn. That's what Ferdco told me several years ago and it has worked fine sense then.
That solved the problem! Thanks!, I tighted it too tight at first and could barely move the lever, easy fix, thanks again
Your welcome ! Glad i was able to help.
