AZ Pete
Braided Hat Band
Hi all -
I am going to make a hat band for a beaver felt hat. It is going to be made out of cowhide. I am going to do a 10-12 strand crocodile ridge braid. I would like the final width to be around 1.25". A few questions I have:
1) Is there a general calculation I would need to use to determine the width of the strands in order to acheive my final width of the band? I am pretty new to flat braids having dealt mostly with whip making.
2) I have read somewhere along the lines that I should not use any leather conditioner when braiding this piece because it might stain the hat. Should I not use anything on the leather at all??
3) Should I be concerned about dying the strands? Will that also potentially bleed on the hat?
Thanks to all for any input.
Regards,
Pete
The general calculation that I use is the width of the string times how many strings you braid. For instance, 1/8th(0.1250) x 10 = 1.25. But since you're doing a crocidile ridge braid you might end up having to add 2 more strings to make up for the ridge in the middle. I am not sure of that part yet myself. So you should experiment with some cheap lace first to find out for sure.
Using a conditioner or a soap is not a good idea for the felt that it will lay against. You might consider pre-conditioning the strings and letting them sit over night to dry out then braiding the next day. This might help out.
I'm no expert at dying leather. I buy all my leather already dyed the color I need. But I have heard that if you dye the hide you will have to seal it when done so that it does not bleed color.
Brian...
Edited by KnotHead
Brian...
Thanks, Brian! I will give that a try and add for the two ridge strings. I think you are right about the conditioning. The leather is so dry I am thinking of giving it a very light coating of dressing and letting it sit for a couple of days so it completely absorbs into the leather but gives me some conditioning. I plan on giving the whole thing a coat of Wyosheen after it is finished to help seal it up.
Thanks again for your assistance!
Regards,
Pete
No prob Pete.
B...
