muzisch
Singer 45K21 Thread Help
Hi,
I have bought a singer 45k21 and the needle is scraping the shuttle frame causing the thread to brake after a few stitchings. Before it brakes it unravels.
I am using a 200 needle with a 10 thread.
Is this a easy to solve problem?
With regards, Dennis
post-42521-0-26922600-1442775201_thumb.j
Hi Muzisch, try another needle? is your needle bar straight? if you have taken the shuttle race apart, have a look to see if shuttle race ring is in the right way around? does the needle hit or rub against the needle plate when going in? could you send a close up? regards jimi.
Edited by jimi
Hi Jimi, Thanks for your reaction. About the needle: I would think this machine could handle the size, and larger? I've made some photo's, hope they help.
In the first picture the needle is hitting a backplate.
post-42521-0-39181900-1442862368_thumb.j
The second picture the needle is hitting the shuttle hook.
post-42521-0-28891500-1442862396_thumb.j
Picture 3 shows the shuttle driver
post-42521-0-16606300-1442862444_thumb.j
Hi muzisch, i meant try another needle in case the one you have in the machine could be bent. and it might be a good idea if you clean inside the shuttle race ring area.
Edited by jimi
so, it's been while... I've found the problem: a bent needlebar.....
That can be replaced easily.
PM me if you cannot find one.
