gentle ben
Oblong Punch For Belt Buckle Tongue
Most versatile would probably be a 3/4" oblong punch. It has many uses beyond your immediate needs. You can always create a wider or longer slot by making two or more "over-punches," though it takes some practices to make it look like only one punch made it. Better slots would be easier to make, though, with a punch the size of the desired hole. What size is that? I find that 1 1/4" fits most buckles well.
I generally use a 1" bag punch on anything greater than in inch in width. Anything smaller, I use the same width as the belt.
