thekid77
Managing Leather Distortion When Casing...
Hey friends,
I am making a simple holster for a small flashlight. I cased the leather for the top piece and pu a couple of decorative creases along the edges.
My question is, when I went to mold the leather to the flashlight (basically a cylinder, the leather became distorted as shown in the picture (which I have exaggerated a bit so you can see the effect)...
Any suggestions?
This is what I did:
-case leather
-crease
-wet form using the bone folder
Thank you all in advance!!! :)
post-35282-0-04519000-1363905175_thumb.j
post-35282-0-03231400-1363906027_thumb.j
Edited by thekid77
You're stretching the leather in at least two dimensions, usually in 3....you should expect distortion. simply do your shaping first, and then do the decorative lines.
I will try my best, just think it will be difficult to do the decorative lines (ie, using a creaser or groover) once there are curves molded into the leather..
It's just part of the skill set, grasshopper, part of the skill set.
Remember...very few set rules to leather working, so go experiment!
If you want perfection, like anything else it's more work!
I make a form and use a press to help form the leather.
I started doing it like you are and wasn't happy with the results.
post-19342-0-23902300-1363960264_thumb.j
nice item Tree Reaper.........tutorial time??
Hi Mike;
Nothing too fancy, just a little extra work to make it work.
I use a simple wood block about 1 1/2 inches thick and then I glue a piece of plywood to the bottom to strengthen it.
You can buy router bits in any size you need, rout the block of wood, I rout about a 10 inch grove in the block and this makes two ends where I can get two separate cases from each mold.
I glue a piece of formica to that and rout that out, this really helps to protect the top of the mold.
I make a matching piece to go inside the groove minus the thickness of leather, the last one was made with clay that can be hardened in the oven.
Use a piece of plywood on top to press on.
Cut a square piece of leather, soak it for twenty seconds, work it into the groove and then put it in the press for a couple of hours then take the mold with the leather and put it in the oven to harden it.
post-19342-0-51882500-1363965707_thumb.j
Edited by Tree Reaper
Thanks for the suggestions everybody :)
I don't mind more work to achieve better results, I was just confused as to the way I should go about making this project work, and your input greatly clears things up!!!
Thanks again!!!
