Howdy pards..
Now I´ve made my first IWB holster for a customer... Want to thank all of you
that have helped me out with tip and pattern..
//BhB
post-13398-028163900 1328030214_thumb.jp
nicely done! I like the extra detail in the boning....
Great looking holster!
Very clean work!
One of the best designs I have seen.
Thanx pards. Its a fun holster to make. To bad I dont have any dummies so I can make it for
Outher guns to.
Here is the back side. Next time I will put the T-nuts betwin the leather.
post-13398-085174900 1328220636_thumb.jp
Awesome detail in the boning! What tool did you use to get such detail?
Thanx Josh.
I just used a bone and a modeling tool.
post-13398-041925300 1328524606_thumb.jp
Edited by Boothill Bob
Thanx Josh.
Beautiful work!.
One thing you might think about for next time is using two tee-nuts t attach the straps. That prevents the straps from twisting and loosening up over time.
tk
Beautiful work!.
tk
Will do that, thanx.
Very nice. I just finished my first IWB holster and posted it also. I have problems with the mouth of the holster collapsing when the gun is drawn. I can still get the gun back into the holster, but I'd be curious if you did anything to reinforce the mouth?
Howdy pards..
//BhB
The reinforcement piece that wraps nearly ALL the way around the holster mouth surely helps.
Another thing you can do is to force-dry the holster with heat after molding. The good thing about that is that it increases rigidity. The bad thing about that is that it increases rigidity.....in a holster that's going to be pressed against your body by your belt......
I've taken to using horsehide almost exclusively for IWB holsters. It tends to be more rigid, either with or without force-drying.
