MatthewMachinist
Stacked Leather Handle For A Knife Project, Prep Dying And Finishing
Hi, I am starting a leatherworking project it's a stacked leather handle for a knife, similar to what you would find on the infamous Kabar -
http://www.self-reliance-works.com/wp-content/uploads/2010/10/Ka-Bar-Stacked-Leather-Handle-400x248.jpg
I have a couple of questions that I need help with, technically the entire working surface is the "edge" of the leather so what products would you guys recommend. I have heard good things about Fiebing products so I would go with Dye Prep for starters, the question is will it dissolve the Araldite glue? Should I use the Dye Prep before or after joining the pieces together?
Next I am thinking I would use Fiebing Leather Dye. I assume I should dye after gluing the pieces together when it is just about finish size, or perhaps when it is at finished size?
I am not sure what product to use after the Dye, is the Fiebing product called "edge kote" a dye or a sealer? Or would you recommend Dura Edge? Are either of these products waterproof? The goal is to produce a leather handle which is water proof, feels like leather, doesn't feel like plastic and has a non gloss finish, What product or combination of products would you guys recommend for finishing.
I have heard some people use superglue to finish after dying, that at least is straightforward, however I am trying to avoid the glossy plastic feel, it doesn't make sense to me to make a nice leather handle then coat it in plastic. As you guys may have guessed I am a beginner and I am quite surprised how little information the companies that make this stuff can give you regarding procedures for use. Thanks.
I made one of these once. I cut the circles, dipped them in epoxy and assembled (tape where ever you do not want glue and wear gloves). Waited a day to dry and worked it into shape on the belt sander. You must cut the circles a little big, there is no way to keep them totally straight. After it was in shape I coated the handle with neet laq to seal the edges.
Aaron
Personally, . . . I would put the pieces together like Electrathon said, . . . making em a little bigger than the finished pruduct I wanted.
I would then put them together on the knife shaft with Weldwood contact cement, . . . but first be sure to scuff up each piece on the hair side so the cement has something to bond to real good.
Once all the pieces are in place, . . . I'd take it to my little belt sander and rough out the shape, . . . put the blade in a vice and finsh sanding the shape with long strips of plumbers sandpaper (it comes in a 1 inch wide or so strip).
I would be very careful and sponge on or daub on any dye I wanted using Feibings oil dye, . . . followed with two or three light coats of neatsfoot oil, . . . and end up by rubbing the outside with beeswax and going over it very lightly with a low setting heat gun to melt the beeswax into the fibers.
You need the oil in there first to protect and help waterproof it, . . . then the wax to add another layer of waterproof plus add some rigidity to the exterior layers of the leather and make it a bit more solid.
Don't forgt to post pictures when it is done, . . . those are really good looking when done right.
May God bless,
Dwight
Hey, thanks for the help guys, I really liked the advice so I went with the following procedure, I used the araldite epoxy glue because I already had it on hand.
1Put washers on handle and compress for a few days(pre compression).
2Remove and sand shiny side to help glue adhere (I skipped the sanding step as it seemed pointless)
3Apply release agent to handle etc so that handle can be removed if needed. (release agent was a leftover from a gunsmithing project)
4Glue both sides of first one, then one side of each additional leather piece, use araldite glue.
5Add pieces quickly and carefully
6Emplace end cap and leave for 3 days to set
7Take close to finish size using grinder or in my case a lathe.
8Sand to finish size, started with 120 grit then 180 fin 240 grit, sand both ways to remove feathers
9Use dye prep x2 coats wipe off excess
10Dye leather x2 coats wipe off excess
11Apply neatsfoot oil, liberally, two light coats should do the job. Leave to settle into leather overnight.
12Warm beeswax and handle with hair dryer and apply beeswax to seal handle.
It was probably overkill using the lathe but it worked well and helped to make it a neat job. I have no regrets using the epoxy. I had to do the job twice though, the first time I sanded with just 120 grit and after dying and oiling I could see feathers or stringy bits coming out of the handle. I redid the handle going to 240 grit and I also made sure I sanded both ways i.e reversing my direction of sanding, logically sanding one way pushes those stringy bits down, sanding the other way raises them up and removes them... I beginners mistake.
The beeswax works really well, you were correct that you do need heat to melt it once it is on the handle, the beeswax was a very nice finishing touch. The best thing is it looks and feels like leather, I am very happy with it but I think when I do my next project I won't make the handle black, I don't think black is the best colour for leather.
Here are some photos, yes I used a little too much epoxy and in one of the photos you can see the feathers that I later removed. http://s1056.photobucket.com/user/matthewdd3/library/?view=recent&page=1
