anester05
Effects of wear on water based dyes and finishes.
I use the Eco-Flo highlighters. I like the effects but I am concerned with what will happen when/if the finish gets rubbed off. I First apply the highlighter then I spray on a acrylic finish. I know that the finish is not water proof just water resistant. Will the dye bleed and come off on clothing if the finish gets rubbed off? Should I use another top finish on top of the acrylic finish? Should I do anything to the stitching gouge line? I am mostly concerned with this for Belts.
Thanks
Adam
