I am new to leather working but I know that for some projects you need to use cement to hold the pieces together for sewing or lacing.
What I was wondering is if I could use a contact cement from a hardware store or if it would be better to buy the leather cement. I am just practicing at the moment so the best cement isn't a necessity. Thanks!!!
Weldwood Contact Cement, Red label. One of the best you can use and its at your local hardware store. Thin coat on each side; Let dry till tacky then put together. I put pieces of wax paper between the two pieces until I get it lined up just right. THen slip out the pieces one at a time and press together as i go. Works great.
Michael
Thanks So Much!!
+1 on Weldwood red label contact cement available at any hardware stores
The red label comes in classic "extra goey" or gel. I bought the gel by accident last time, and I have to say its less mess and has worked just as well. It doesn't string out like hot cheese on pizza like the original recipe.
