autumn at subshop
Motorized Leather, Rubber Or Plastic Cutting & Strapping Machine, Model Ak20 With Stand And Spare Pa
This model AK-20 multiple knife roller feed strap, belt, and strip cutting machine is capable of simultaneously strip cutting up to 14" width of the
same or varying widths of leather, rubber, paper, cardboard, or other similar materials. Simply place the spacers between the knives and it will cut the material straight and evenly.
Serviced regularly, new motor.
Parts are easily available for this machine when needed such as new rollers or having the blades sharpened.
INCLUDED PARTS:
- 1 set of 6 nylon rollers (used) + 1 new spare roller
- 39 pcs 1" steel spacers,
- 30 pcs 3/4" steel spacers
- 32 pcs 5/8" steel spacers
- 30 pcs 1/2" steel spacers
- 66 pcs 1/8" steel spacers
- 50 pcs 1/16" steel spacers
- 72 Knives (round), sharpened
- 28 Blade Guards
- Manual and special tool for adjustments
- Specialized stand/ table
The AK-20 is mounted on a flat table top with adjustable "T" style legs and locking caster wheels. This model cuts material up to 14" inches wide in increments you choose with the provided spacers. (You can feed larger materials than 14" into the open end of the cutter to cut up to 14" off in the first pass.)
An adjustable fence starts the first cut. The machine cuts endless lengths and is powered by an electric 1 hp clutch motor.
The machine may be run up to 1100 RPM to cut large lengths or may be run as slowly as you wish to control the feed of the material you're cutting. The operator controls the feed rate, the width and the quality of each cut. The AK-20 will feed and cut up to 256" of material per minute.
If you regularly cut materials into uniform widths, this machine is an incredible time-saver in your shop that will pay for itself quickly!
Impeccably maintained, don't let this machine get away!
This machine sells for $1200.
If you are in the Milwaukee area, you are welcome to pick the machine up. All the machines come exactly as shown and are "as is". We accept Cash, Check (with a 10 business day hold) and Paypal (+7% fee - which is what paypal charges). Our organization is 100% volunteer run and 100% of all proceeds directly benefits Layla House Orphanage. You can email me at autumncomgr@gmail.com to discuss shipping options.
post-34901-033013200 1347648774_thumb.jp
post-34901-050053100 1347648785_thumb.jp
post-34901-036124200 1347648795_thumb.jp
post-34901-031450100 1347648812_thumb.jp
post-34901-069637700 1347648825_thumb.jp
post-34901-048280900 1347648838_thumb.jp
post-34901-016968000 1347648853_thumb.jp
Hello your machine is of $1200 but I have seen machine that is bit affordable for me. I thinks it has some more features as compared to your one. please reply me I have to take my final decision.
Edited by Amelie11
