kiltedcelt
Question About Veg-Tan Leather And Tooling
I'm not entirely new to leatherworking but I feel I have a couple of newbie-ish questions. I've made a few leather quivers (I'm into archery) and I'm looking to make more and do some other things like arm guards and even some non-archery related things like a laptop bag/satchel. I have a few 5-7 oz. tooling sides and my question about them regards the flesh side of the hide. In all cases, the hides I have the flesh side is rather rough in appearance. Also, these are un-dyed hides which I prefer to dye myself to get the colors I want. In some instances the roughness of the flesh side of the hide doesn't cause any problems, however in other instances such as making arm guards, I'd rather have a smoother surface on that side of the hide. How do you get a smooth finish on the flesh side? Am I the victim of buying poorly prepared hides? I could swear I've seen veg-tan tooling leather (un-dyed), that had a smooth surface on the flesh side. I've tried sanding and scraping and that just seems to keep messing things up and frankly I think if you tried too much you'd end up with a lower weight hide simply by removing too much from the flesh side. Now, for the second part of the question. I'd like to get into doing some tooling as well and while I understand the principle and have even seen a minor demonstration of tool usage from a fellow (much more experienced) leatherworker, I'm stuck as to where to begin with tools. I mainly want to stick to mostly simplistic geometric designs. Cross-hatched designs, linear kinda stuff, a bit of Celtic knotwork, that sort of thing. Not a lot of flowery Al Stohlman western saddle type stuff. That's not my style. Should I just pick up a Stohlman book, because I'm assuming the techniques are going to be the same regardless of the design? Also, anyone have any suggestions of basic tooling stamps to get started doing simple patterns? I think I'd like to steer away from sets because most of them seem to have duds in them that I'd never see using. Also, one final question. I've done all my stitching up until now with 1/8" thonging chisels and waxed linen cord. I'd like to continue that route because I like the look of the linen cord but I want to get smaller stitches. I see that the next size down in a thonging chisel is only 3/32 - a whopping 1/32 smaller in size which I think is still not going to be as fine of a stitch as I'd like. Am I looking at using one of those roller wheel tools and going along and using an awl to punch out individual tiny holes much closer together? Or, is there a tool (aside from a sewing machine), that will allow me to make finer stitch holes? Or, am I wrong in thinking of making finer holes because maybe the smaller the hole and the closer together the stitches, the more likely the seam will not be as strong? Anyway, that's all for now. Thanks in advance if you can point me in the right direction.
A lot of question there. Part one, the flesh side of the leather can be finished or slicked. Light sanding will make the fibers stand up, which is what is needed. Then wet the leather, apply some yellow paste saddle soap to the flesh side and rub briskly with a rough cloth like canvas. This will make the fibers lay down. Let it dry and apply any type of leather finish to protect it from comming back up.
Stitching, I suggest that you buy the Stolhman book, " Hand Sewing Leather" he gives you a lot more infomation than I could type here. By using the overstitch wheel to mark your holes and an awl to make the holes you can get a nice stitch you cannot get by using the chisels.
Randy
Randy
Celt,
Randy is spot on here. The book from Al Stohlman will answer all you questions on stitching, and much more.
Bob
I've tried the chiesels and didn't like them becasue the holes are way too big. You need an overstitch wheel to mark you holes and then use an awl with a diamond blade. Al Stohlman has an excellent book on hand stitching that will really help. I don't believe your leather will get any weaker as long as you punch your holes diagonal and not horizontal. You can get a wheel from Tandy that has three different stitches per inch. Everything I do is 7 stitches per inch. I have read of the old masters stitching up to 17 stiches per inch, but that would be very difficult. Get the Stohlman book and it will answer most of your questions. Hope this helps,
Terry
