Hi everyone. I'm pretty much a newbie. I just got some new leather I'm planning to use to hone my tooling skills. The stuff is very thick and stiff. I'd like to condition it before I start working with it but I'm cconcerned that applying oil or a conditioner like Lexol might make it less useful for tooling. I've already worked it over with glycerin saddle soap and that seemed to help a bit. Any suggestions?
You do not want to soften it, if you did you would not be able to "dent" it propery. That said, I usually use Lexol before the knife cuts to make the knife slide smoother.
Aaron
Aaron
Thanks, Aaron. That sounds like a good tip.
Debbie
You can case your leather real good with your casing solution, then apply a few drops of Lexol and a few drops baby shampoo, that will help the knife slide through.
Question. Do you add the Lexol to the casing water? Or do you case the leather and then spead on a couple of drops to the leather?
