BigGriff
Chaylor Fenneli Interior - What Do I Do With It?
I bought this interior with hopes of learning enough to eventually use it, but I have to be honest that I am still not sure what to do with it. I have a piece of burgundy chromexcel that I would like to use as the exterior. The way I look at it is I have two options, but I am not sure which is correct.
Either way, I assume I would glue the chromexcel to the bigger piece of the CF pieces, but I am not sure if I am supposed to leave some extra space on the chromexcel, skive the edges and fold over before I sew OR would I cut the chromexcel to size and burnish the edge?
I have heard that chromexcel does not burnish that well. Any help is appreciated.
post-27686-0-99987300-1392246654_thumb.j
There are tabs in back of the card slot pieces. Slide the diamond shaped piece end into the opening of the card section and hook the tab into the slot. Do it on both sides. The rectangle id the liner to the back. Sew or lace around the perimiter to hold it all togeather.
Gotcha. Now what's the best way to finish? Make the exterior a little big, skive and fold over or make the exterior piece the same size and try to burnish? Or does it matter? I starting to think skive and fold the edges may be best.
