olandrea
Pull Through Splitter, Maximum Width You Can Pull?
I have to split down some bridle leather from 4,7mm to 3,5m what do you think the maximum width you can pull even If you do this in several passes? I tried a width of 19cm and there is no way I could pull it trough!
Thanks Olaf
You didn't say how wide your splitter was. I have an Osborne 84 8" and if my blade is sharp and stropped I can pull 6" with relative ease.
Good sharp blade and leather with some body I can usually get about 1-2" less than the blade width without a lot of trouble. On some I am doing the one side and then the other to get through. Depeneds on my leather some and what flavor of splitter I am using too.
