raysouth
Flat Leather Bracelt Hardware/clasps
Howdy Folks,
With all of the searching I do on the net, I have been seeking sources for hardware, primarily clasps/latches/catches, or whatever the proper name may be, for flat leather bracelets.
The closest I came was to a t-bar type catch now being offered by Tandy. Searched Ohio Travel Bag and still nothing that I could find. I have been asked to make a small volume of different flat leather bracelets varying between 3/4" and up to 3" plus but the request threw me when they asked for multiple different styles of catches. I found a ton of sources for round and braided type bracelets but not much of anything else for flat leather use.
If anyone has any idea of a source or sources for this hardware, please help me out.
God Bless.
Ray
Hi, Ray!
The keywords you want to use are more like "leather bracelet findings" - "findings" will be a more inclusive, general term since companies will list them as clasps, cord ends, etc.. Also, you probably need to look more at jewelry suppliers rather than leathercraft suppliers. There is a newer brand now that is pretty widely available called Regaliz, so you could google that, too. For instance, on Etsy, I entered "Regaliz leather findings" and there are 1500+ results: https://www.etsy.com...to=US&ref=auto3. Another common brand is TierraCast, but I think the Regaliz style ones are more likely what you have in mind.
If you'd prefer to order from a company rather than sellers on Etsy, here are some other suggestions:
http://www.fusionbeads.com/
http://www.beadaholique.com
http://www.rings-thi...KigzCjzRDoUZQ.0
I hope that helps. Let me know if you need any more help!
Elizabeth
Hello Elizabeth,
Thank you for the information and yes, there is a few items there that I will be able to use.
I do prefer to order directly from suppliers, when possible, as costs can soon become beyond what I could expect from return on investment. I am not a major seller, by any means, just on fixed budget, most of the time.
I am always amazed at the different terminology used by the craft and suppliers. Words I would never think of using. Never thought of using "findings" even though I have seen it used elsewhere for a couple of things I was seeking. Never learn enough and I suppose that is part of the pleasure of crafting.
Again, I cannot thank you enough for the assistance. You have led me down a new and wonderful path of enlightenment and I will be forever grateful.
God Bless.
Ray
depending on the size of the leater you want to add the clasp to, you may be able to use what is called a "ribbon clasp". They are small clasps that you crimp down and come in various sizes. Usually also found in the "findings" area.
