talon
Adjustable Retention Screws
I'm curious what you guys use for adjustable retentions screws that use a rubber spacer. I've seen a number of holsters that use this, but wondered where to find the right hardware.
Thanks
t-nut, rubber grommet, finishing washer, and screw.
Some, including me, use clear 1/4" hose (tubing) from Lowes for the spacer. Bought a 10 ft. piece and just cut to length.
I'm a bit skittish about mentioning anything I use because of past responses.
Check Tandys listing for open backed Chicago Screws in Brass or Black, you can use a counter sunk 8x32 for the screw matched up with this post and it will look like it belongs there and not half done.
