NC Holster Maker
What Drill Bit Size For #277 Thread?
What size drill bits are you guys using for your #277 thread? Also what size needle are you using when using drilled holes for your stiching layout?
When I need to drill holes for hand stitching I use a 3/64" bit.......it's more of a pilot hole since I still have to use the awl to make the hole big enough to allow the needle's eyelet to pass through.
I'm not sure of the needle size, it's the one Tandy sells in a 10/pack.
The smallest possible hole that will allow the needle and thread to pass through. Then one size smaller! The only time to use a drill bit is two or three layers of leather and a filler Strip! Otherwise an awl.
Some say you should have to use pliers to get the needle through. Maybe yes..maybe no?
