DEADEYE
Is This The Correct Osborne Chisel/punch For Hand Stitching?
Is this the correct chisel/punch for hand stitching belts knife sheath's and holsters?
http://www.csosborne.com/no700.htm
Seems to me they were suppose to be a little on an angle if I recall from the "70's"
Here are somemore
http://www.csosborne.com/chisels_1.htm
TIA,
Deadeye
You could use the Osborne chisel, or you could buy a less expensive diamond hole punch from Tandy. This produces about 7 stitches per inch.
Any of them will work... There are so many differant ways of doing it. If you are trying to be a purist and do it "corectly" the pricking iron listed in the second link is what you are looking for. Then you use an awl to pierce the holes through the leather.
Aaron
