Sticky
Will This Work
Hello everyone
Has this been done before?
If you had a steel plate which has had a vinyl sticker put on it in the form of a negative image and then you put a piece of vegtan on top that has been soaked in vinegar
would the image be transferred to the leather if you left it covered for a day or so?
Any ideas anyone
Cheers spencer
I have not done it, but I have left a piece of metal touching wet leather. It definatly leaves a mark. It did not leave a crisp line, more of a blured edge.
Aaron
Would like to see if if you try it. I am curious now.
Hello everyone
Any ideas anyone
Cheers spencer
You wouldn't need to use vinegar, just dampen the leather and put a sand bag or something heavy on it for a day or so, even if it doesn't stain the leather, the sticker has thickness, it will leave an impression you might be able to highlight it with antiquer
cheers
mike
I tried it and it didn't quite work :( i'll try it again but i wont wet it as much this time as the the colour bled over the lines.
Will post pictures if it works ok
Any color transfer could likely be inconsistent because the color change is a result of a chemical reaction. You might try cutting a line around the negative image (on the leather) to prevent the reaction from wicking through the leather fibers.
I was trying to get a sort of screen printed image.
I think it's going to one of those ideas that doesn't quite work!
(I'm still going to give it another go though)
Try Lemon Juice, It will transfer certain inks from paper to paper or leather but I don't know if it will work on vinyl to leather.
Blake
