Hello All,
This project is pretty much wrapped up now - Assembled this last night.
I'd like to say thanks to all who helped me out on this project and to all who pointed out things I should do different next time - This forum/website has been the most valuable education tool to me so far...
Now, I would like honest criticism from all of you saddle makers out there - I want to know what to do different /better next time. I am open to all critiques on fit, shape, function etc...
A few things I have noticed:
1. Rear jockeys - Not tight enough - Didn't cut them deep enough so very hard to get them really tight. Next time will add 1/2" extra.
2. Rigging plates - Too round on front edge and too far up fork - not quite as clean as ideal @ front end.
3. Cheyenne roll - Stitching on back looks like hell. Need to really practice on that,
4. Rear rigging plate set too high. Caused issues with seat ear and saddle strings
5. 13" Wide cantle - Probably do a 12.5" or maybe even 12" next time.
5. Plug rigging plates next time to eliminate bump @ rigging plate.
6. Consider using 2.5" stirrup leathers.
Here are the pics I snapped yesterday evening - Oil is still evening out.
01
02
03
04
05
06
07
Once again, thanks to all who helped me on this!
Kind Regards,
Ron L
Ron awesome job on the saddle. Heck awesome just considering doing one. I think it's beautiful. Cheryl
Ron,
I think you did a fantastic job on that saddle. The one thing that really jumps out at me is the placement of the screw at the fork. I would move that up and forward. It looks like your leg might rub on it now. It could even cause some interference with the stirrup leathers. I like to put them about he center of the fork and about 3/4 to one inch down. Once again great job. You got your next tree ordered yet?
CW
Ron,
It looks good, especially for your first, wouldn't have known it if you didn't mention it. Not much to critique since you've mentioned most items; and, that's mostly in your mind. I do have one suggestion, and it's only the way I do it. I've found that if you reverse the way you put on your horn wrap, you'll center the wrap on the front of the fork better, so that when setting the saddle on the fork and horn, it protects the front of the fork cover better. By this I mean, take your wrap forward and around into the hand hole instead of going through the hand hole first.
Also, as straight forward as rear jockeys appear (like no brainer as far as construction) they can be a real pain to get them centered and looking in proportion to the rest of the saddle. I've had on occasion to make three sets of jockeys until I got what I wanted.
Can't wait to see your next creation,
Ron
Your saddle look pretty nice to me. Yes there are things to change. There always will be. Everybody makes changes until they can do it in their sleep.
Now to ( your )critique.
3. Cheyenne roll - Stitching on back looks like hell. Need to really practice on that.
I have found that a lot of production saddles look pretty bad too.
I use a method I like when my stitching is likely to show on the rear of the Cheyenne roll.
I center my stitch measurement wheel and make the stitch marks on the front of the cheyenne roll. Then I push my awl through the center mark at the top of the cantle as straight as I can. Aiming to hit the groove on the back side.
I then take the whole left on the back side by my awl and once again use the stitch marking wheel centered on the hole I just made. For me, this method pretty much lines up front and back stitch marks. Then all I have to do is aim well when I press the awl through.
Your mileage may vary. :)
Joel
Ron, I thought that I commented on this last night, but; maybe I was just dreaming! Any way, yes you will always find things you will want to do different on the next one, but all in all, you done good pilgrim. Now all you need to do is ride it!!!! That's where you will find your likes and dislikes.
Bob
Ron,
You know I do not have the trained eye that others do, but the 'flow' looks great (rear jockeys onto the skirts and the seat jockey). It all 'fits' together. I can see the issue you point out with the rear rigging but it certainly doesn't look bad. I see CW's point on the screw also. If either of those are your worst mistake, pat yourself on the back.
I really like the tooling on the rear jockey. The way that you blended the border and basket weave with the floral design. Very nice indeed.
Take some time to ride it before you start your second.
Randy
This is really a nice job for a first saddle. It looks way better than my first one. Back when I started, there were very few books, and damn poor ones at that, and no videos. Most of my education has been (and still is) seeing what was wrong with stuff that came in for repair, knowing what I liked personally and what irked me about equipment I used, and lots of trial and error. I'd pick up a little here and there from asking lots of questions of the guys whose work I liked. I'm still learning every day and I've been working on saddles for about 35 years.
For the critique, and I by no means consider myself any kind of an expert, besides the things already mentioned by others, there are several things that you could work on when you build your next one. First of all, the Blevins sleeve is on backwards. The plate is made to fit into the recessed area of the slide, and the printing on that recessed area should be right side up. Try it and you will notice the difference. The Nevada twist could be better. You have only twisted the fender leg, and I like to build some twist into the whole fender. Notice how the end of the fender leg, where the Blevins plate is riveted in, looks like it is starting to un-twist. The stirrup leather is affected by this, and would not lay flat against a horse. I would also work on finishing your edges a little more. I see little fuzzies, and it's not a real slick burnished edge. There are slight imperfections made by both your knife when you cut the parts, and your edger. These are all picky little things, but if improved, would add to the overall finished look of your work. I would bevel the sheepskin back a little more. There are places it looks a bit ragged. I use an electric sheep shearer as well as a mane roaching scissors., and spend a lot of time on this step. One other thing that can be tougher to get right is the front of the fork cover. I would bring the edge of it a bit further forward so there is no lip showing in front of it. It took me several saddles before I was satisfied with the front of my fork covers. And since there are several different ways to finish the front, it takes that many more to become proficient at all of them. I have a drawer that is specifically reserved for saddle parts that I have messed up, and there are 2 fork covers in it. They can be a challenge.
I like the tooling on the rear housing also. Tooling is not my strong suit, and I don't enjoy doing it as much as the other steps in a saddle project. Plus my hands are full of arthritis so it hurts! Nice job and let us know how it rides.
Hello All:
Thanks for the kind words and the critiques!!
CWR: You had me sweating on the screw location, Luckily I am tall and skinny and like to ride with my legs hanging fairly straight down! In this position the screw is about 2" away from my leg even when I swing my stirrups as far forward as I can! However, going forward the screw location will be up and forward!!
Grampa Joel: I will have to try that trick - The worst problem I had was trying to aim the dang awl...I would do good for seven stitches and then get off track...hard to correct once you have a hole where you don't want one.
Big Sioux: Thanks for the compliments but thanks even more for catching issues! Can't hardly believe I had that one Blevins sleeve on backwards - Not sure what I was smoking when I put that on... I agree on the Nevada twist - I noticed it didn't sit like I wanted it to but I wasn't sure what to change...Any advice on what to do there? This morning I tried to squeeze some twist into the entire fender length...I will also try to get some more twist on the actual Blevins buckle area...Any tips you have to do this better will be appreciated. Regarding the fleece - I used a pair of $30.00 walmart electric hair clippers - Worked good actually - However I will go over again and clean up the edges...And regarding the fuzzies - Burnishing is not my favorite activity - However about the time you must have been typing this I was going over the saddle edges with canvas, a bit of moisture and beeswax...I'll keep at it until they stay down forever...Seems like I would get the edge looking great, then, a few days later they would re-appear...The fork cover - I agree on this too - I wish that lip was about 3/16" to 1/4" farther forward..When I test fitted it, it looked good -When I actually glued it up and stretched it in the dang thing refused to work forward - I'll bet I spent an hour and half trying to coax that thing forward...However, next time I will know to make the fold about a 1/4" forward of where I did last time...
Anyhow - Thanks for catching these issues, really helps to get another viewpoint and a more experienced eye on it - I've got a second tree on order with Glenn Christman... See if I can't resolve some of these things on saddle #2.
Anyhow, likely take this thing out on Saturday and see if we can't get some rope grooves worked into the horn wrap and pack that fleece down a bit...I just hope the seat I put in proves comfortable...
Keep the critiques coming!
Regards,
Ron L
Ron I will address your questions either tomorrow or Monday. I will try to get a couple pics of what I am talking about on both the fender and fork cover. I don't have time today; have other stuff going on that I can't possibly wiggle out of:) Have a great weekend!
Well - Put about 11-12 miles on the new rig on Saturday - I'm pleased to report that it sat good on the horses I rode and sweated both of them up real even. Noticed it really seems to sit where it's put...Didn't have to cinch it up nearly as tight as my old saddle to keep it from rolling.
Anyhow, it also seamed to fit my rear end good too...Biggest challenge for me on this project was to order a tree that would the majority of canadian ranch horses...I don;t own my own horses - I ride for other people and it was important to me that this rig would fit your average horse. Obviously I'll need a lot more time on this thing to really determine how well it fits but s far so good.
Never had a chance to rope anything off it on sat but that will happen soon... Bottom line is so far so good and I am pretty happy with how it feels for me but more importantly how it sat on the horses...
03 On horse
01 On horse
R
Very nice for your first saddle!
You should take great pride in what you have accomplished.
Regards Billy
As the addage goes, since you asked. The list you made pretty well has it covered so I'll use it as my format and see if there is anything left over. #1 actually that has to come after #4 and then locate the bottom line of the Jockeys, my practice is to cover all rivits.
#2 Yes and I encourage you to stop doming rivits. It looks nice but domed heads will wear quicker and uglier
#3 Bruce's trick will help and even before that, using the biggest french edger you have, skive down and even on cantle back cantle filler and seat so that you will end up with a reduced thickness to sew through and if the 3 pieces (+2 for the 2 sides of the cantle binding that you have to sew through are no thicker than need be and are even in thickness throughout they will sew much easier and truer. Also, look at your awl blade. If it is a slim it probably deflects a bit, consider a thicker, stouter blade that won't deflect.
#4 Remember all the issues and lessons learned when laying out Plate in 1st place.
#5 if you have a tiny hiney OK but otherwise, why sacrifice a comfort feature?
next #5 Lesson learned.
#6 Best choice most of the time.
AND NOW
#7 Is the right side of the front cover left untooled for a reason?
#8 I'm assuming that front cover at the top of the gullet is not too short on purpose. Here is a good place to illustrate that the angle at which we hold an awl, spike or pencil matters as to whether or not the mark we make is the actual fold line or a reference line from which we scribe a fold line to put it where we need it to be.
#9 I'm NOT a fan of the Dale Harwood style of covering a horn and butting it up to the edge of the hole in the fork cover. If you remove the mulehide or burn it off, IMHO you should find a finished surface underneath that will hold up until you can get the wrap replaced or put back.
#10 That little unsecured by sewing point on the front of the horn cover is vulnerable to quick and ugly damage.
#11 Now on #NEXT you will have a lot to think about when you fit your skirts.
But the bottom line is still ya dun good
Oltoot:
Thanks for commenting on this for me!
#2 & #6 - Rivet Doming - Yes,I am going to quit using the domer I have - Douglas Tools makes one that just eases the lip over a little but leaves the rivet largely flat. I may purchase one of those.
#3 - I like the idea of thinning it down - I figured I was sewing through about 1.25" - 1.5" of leather when I sewed that cover on...my awl is a Douglas tools awl from Sheridan Leather - Seems pretty rigid to me. I think the deviation was me not having the hang of it...I would have to say that sewing the Cheyenne roll was probably the hardest physical work on this project - Pushing an awl at 5 spi through that much leather isn't my idea of a party!
#5 - Point taken and I agree - I don't care for saddles that pinch at the cantle corners.
#7 - My theory was that the my rope (while tied on and bouncing around) would wear through tooled leather swell cover faster than just smooth leather - I would like to hear if this is actually a concern there.
#8 - That front lip at the top of the gullet is probably one of the things that bugs me the most. Next time I will scribe a line 3/8"+ from my initial scribed line.
#9 - I am not sure what to think here. My reasoning is that if a horn cap gets trashed it's an easier job to fix. However I can see your side of the debate too...so now I don't know what to think :)
#10 - I agree now that you point it out...Next time I want an off round cap I will order a guadalajara horn cap
#11 - Yep - Block in place, cut after is my new guideline until I create a pattern I really like.
Anyhow, thanks again Oltoot and everyone else who has commented - It sure helps to get experienced eyes on this.
Next saddle looks like it will be a Weatherly tree - However the guy wants a wood post style horn but wants the cap real small - Like 3" finished and then the neck to taper down. So It will have t have a metal horn - We're having a hard time sourcing a metal horn with that exact shape...
Hopefully do some roping on the new rig this weekend!
Regards,
Ron
