Scary Leatherworks
Question About Maverick Style Bag
I posted this in the "bag, briefcase" section a few days ago but I don't think that forum gets many visitors so I thought I'd try here also. As the title says any ideas how to make the top of the bag more rigid so it can be carried without the top lifting/bending. the bag is in the style of ESantoro's I can see on his he has another piece of leather on the underside stitched to the top is there anything that should go between as an added stiffener
thanks
Scott
I think normally what is in there is a steel bar that the handle is riveted to. You could probably hit up the local hardware store or metal yard for a length. I've never actually done it before so as far as gauge/size I don't know.
Andy
thanks
Scott
scott, go and buy you a large cheap office folder, the one with 4 metal rings (ringfolder?) remove the rings from base and use the holes to rivet to top flap....makes nice stiffener. Or go to Lowes or Homedepot, buy some 1 inch or a bit wider aluminum flats....drill, rivet...done....makes great stiffener and makes your bag look square too!!
James
