srbonner
Push Beader Help
I have been using the push beader that I got from Barry King. I have got it down pretty well, BUT I'm having troubles with square corners. Can someone tell me the best way to work corners. Thanks in advance-
Hello srbonner,
You are dealing with a common problem. Push beaders can't do a square corner very well. Typically people deal with it by using a seeder in the corner to fill that space, so the beader lines don't have to meet. Otherwise, if you need the lines to meet and form a nice corner, you need to use regular bevelers to bevel the corner and make it blend in with the beaded border.
Hope this helps,
Bob
