Here's my latest belt recipe:
* 1-1/4" belt blank
* antique nickel-plated, solid brass buckle
* two chicago screws
* Fudge Brown Eco-Flo color
* Fiebing's EdgeKote (Black)
* one coat of Lexol
* three coats of Satin Shene
Mix ingredients, combining with a healthy portion of elbow grease.
p.s. After giving away my last few projects, this one's gonna ride on my waist for a change! :)
Edited by abn
Very nice!
Very nice. That's the same buckle I have on my 1 1/2" belt.
Yeah, I wasn't sure I was going to like the buckle's brushed, antiqued look since I've always used polished buckles, but Tandy didn't give me a choice in 1-1/4" nickel-plated, so I had to try this one out. I kind of like it.
Thanks for all the comments, fellas. Much appreciated.
Regards, -Alex
Really nice work---clean.
How did you do the borders-(is that a stitch groover cut or a cut line that you beveled?)
* 1-1/4" belt blank
* one coat of Lexol
Great belt. When do you apply the Lexol, before the dye and Satin Shene?
nice clean belt!
i still need to take the time to make one for myself );
Pete, thanks for the kind words. The lines were cut with a Craftool Adjustable Groover. They show up nice and dark thanks to the Eco-Flo All-In-One Stain. The All-In-One stuff, unlike the dyes, will highlight grooved lines and stamped tooling.
Oh, definitely before. Lexol will lift water-based dyes and stains, so I apply a liberal coat of Lexol before dyeing. If you have to apply Lexol after the dye job has been done, make sure the dye dries overnight and then use a really light touch.
nice clean belt!
Yeah, Beez, I was thinking about you when I mentioned this belt was for me. However, you haven't been a total leatherwork martyr... I think you made yourself a motorcycle seat not too long ago, and a nice one, too! :)
Thanks again for the comments, -Alex
LOL!! very true!
i really need to make myself a couple nice belts. i have purchased a couple of nice buckle sets but just have not taken the next step. i also have to wear a tie a couple days a week and have been gonna make myself a tooled black leather tie :spoton:
Shirley,
Thanks for the kind words, but I can't take any credit for the color. The new All-In-One stains make it so easy a caveman can do it. :)
Seriously, I hated spirit dyes. Mainly my fault -- I never made the effort to try different mixes or application techniques. I just used the provided dauber and slogged it on straight out of the bottle, and then the cussin' starts. :ranting: I got so downtrodden over my results that I went for about 12 months and the only color I'd use was black.
I think all of us have our strengths and weaknesses. For example, I'm a pretty good hand-stitcher. But I can't carve or color worth a damn. So, I look for the easy ways when I can!
Have a great weekend! -Alex
Your work always looks very clean to me but, i gotta tell ya i'm always amazed at your stitching .I did a few practice runs about 6 months ago or so. I was all over the place. I just tried to hand stitch something tonite and i'm having a hard time keeping it tight and clean.
Are you using a dauber with the all-n-ones ? I like them, they cover well but when i do a mid-size job or something long like a belt i get "strikes" with the dauber .
When hand stitching are you using a horse and what size thread and needle are you using ?
OH, and i like that color. I think i need that color.
sign,
2 needles and no clue
sign,
Hey Freak!
Have you ever tried using a hand stitching punch for making your holes? C.S. Osborne makes them. I got mine from Hide Crafters. Cut your stitching groove deep, make the holes with the punch, and as long as you pull the stitches the same direction each time, it's fool proof. They don't have a single punch, though, so I use a little scewdriver the same width when I need one. I have a terrible time with the awl, and was beginning to really dislike hand stitching. George Hurst put me onto this other method. It works for me, maybe it'll work for you.
Yak steaks for dinner tonight! :thumbsup:
Kathy
Freak, thanks for your kind remarks. Much appreciated.
I do handstitching in an unconventional way, so bear with me as I explain. The first thing I do is create a deep stitching groove. Within the groove, I use an Overstitch Wheel to produce an even row of marks. With the project flat on the bench, I strike a Stitching Awl with a mallet to produce the stitching holes. (Most books tell you to slant the diamond holes made by the awl for a stronger stitching line, but I keep the diamonds lined up straight up and down for the straightest line. Hope I'm explaining this well.) When doing the saddle stitch, I always start the stitch from the same side (normally the back of the project). I use Tandy nylon thread and regular old needles.
As you can see, this isn't the recommended way of hand stitching, and is probably slower than using a horse, but it works for me so I can't complain. :)
I tried using a dauber with the All-In-Ones, but didn't like the results. Nowadays, I'm using a slightly damp paper towel to apply the finish, and a completely dry one to take off the excess.
As you mention, All-In-One is a finicky finish when doing large projects. The folks at Tandy told me to get it all on at once since you can't do a second coat. It seems all the second coat does is pull off the first one, and I can confirm that is indeed the case. The only problem is that I'm too clumsy to get that first coat on just right. So, this is what I do:
Do your first coat as best you can. Then remove a lot of it using a damp paper towel. You'll be left with what I call a base coat -- a much lighter and duller color than you really want, but definitely darker than the leather itself. Let this dry for a while, and then go back and very carefully apply a second coat with a scrap of white cotton t-shirt. For me, at least, this technique allowed me to get a more even color on a larger project.
Sure hope this information helps.
Regards, -Alex
I think that helped A LOT . So you just use one needle and stitch one way and then fill coming back ?
Thanks for taking the time to write that up.
No, I saddle stitch with two needles, but I always start the stitch from the back of the project. I think the idea is to do each stitch exactly the same so they look more uniform.
