mlapaglia
Looking For Suggestions On How To Make This Case
Take a look at the case below. It holds a jewelers magnifying loupe. From what I can see and tell there has to be a small piece glued inside the case along the stitch line to provide a shoulder to stitch between the two sides. A triangle shaped piece would work pretty. one side for the case wall and one side for the case side. Glue and stitch. I thought it might be the side set in a grove but that would make the stitches exposed on the inside.
Thats how I would do it. Anyone got any ideas? is there a better way? Would my way work?
Thanks
Michael
post-22515-035361000 1319858740_thumb.jp
post-22515-050256100 1319858741_thumb.jp
post-22515-015166700 1319858742_thumb.jp
post-22515-093808300 1319858742_thumb.jp
It's called a box stitch, and can be done with no welt. You're effectively just sewing at an angle through two pieces of leather. What you are viewing as the side and edge stitching on the case, is actually the top and bottom stitches.
Check your PMs if you haven't.
