Hi all,
I've been working on a camera bag, but I've run into a problem. The seam where the three corners meet at the bottom of the bag looks really tacky, and I'm not sure what I should do, or what I should have done to avoid the problem.
Any advice would be appreciated!
Monica
post-38542-0-18074500-1389887025_thumb.jpost-38542-0-15124100-1389887028_thumb.j
Edited by MonicaJacobson
The stitch is too far away to pull the pieces together.
You could drop some crazy glue in the hole and clamp it tight, maybe consider a rivet if there's enough room for one.
Ah yes, I see what you mean. I went back and found a bigger picture on that website and finally saw how they dealt with it. (http://ep.yimg.com/ca/I/yhst-80923275928354_2272_9466493)
Thanks! I'm going to restitch it, and next time I'll just do what they did.
It looks like they just rounded the corner.
post-19342-0-98856600-1389895833_thumb.j
Edited by Tree Reaper
I believe their bottom layer is all one piece, which allows them to dispense with the three cornered edge altogether. A much better solution.
That could be, I can't make it out from the picture.
I agree that would be a better solution, you know you have to make three of everything to get the one you want.
Ha, that's slightly comforting. ;)
