picola
Help To Choose The Correct Sewing Machine
Hi I am new in working with leather I am a fashion designer but I am started to create some leather handbags I just want some advice what is the best sewing machine that I can buy I am considered this model but obvisuly i need a little help telling me if is the correct one
Techsew 2800 Cylinder Walking Foot Industrial Sewing Machine
this is the wedsite where I saw the machine
http://shop.raphaelsewing.com/index.php?main_page=product_info&cPath=30_32&products_id=496
all the advice will be helpfull thank you
If you're interested I'm a flatbed sewing machine, I have a consew 206rb for sale and I'm in your area.
As for the techsew, they're not bad. I have a pfaff 335 which is what that machine is a copy of (at least an older model) and they would work just fine for purses. I see my bags on the 335.
Andrew
Thank you Andrew for the reply, how much do you asking for the consew 206rb
Also check with the Leather Machine co and Toledo sewing both supporters, here
ck look at top banners
Steve LMC is near you, west coast and might have a good option at a fair price,
close, top notch service and support after the sale very important db
ALSO Very important before you buy Clearly define your current use , it will change and vary over times
light weight only 6 oz or less or heavy bags like a messenger
if you can narrow the range,,, better chance for best first choice
as you develop your style/ selection you WILL find the need to add more options to do bigger/ heavier material
if you choose to and add a heavy sewing then
also cylinder arm machines You can add a table for flat use as well as ???
Edited by Greystone
thank you for your help I will check it I did.t see the banner of steeve
I saw it thank you Greystone
Thank you Andrew for the help I will check
