Nuttish
Steel Drive Wheel And Presser Feet For Fortuna Style Bell Knife Skiving Machine
I'm looking for a burred steel drive wheel for a Fortuna style machine. My stone wheel is clogged and doesn't appear to have been adequate to feed heavier pieces even when it was new.
Also looking for presser feet or will pay someone willing to measure, trace, and photograph theirs so I can machine them.
Any leads appreciated.
Thanks.
Make sure your unit is actually a true copy of the Fortuna. Most skiving machines other than Fortuna are nearly identical but do not have the same type of presser feet or the feed wheel.
My Cowboy has the serrated metal wheel. Easily cleaned.
ferg
It's from the 50s or 60s and looks absolutely dead identical to older Fortuna's I've seen, but how would I know? The manual doesn't show dimensions, not that Fortuna manuals do either.
I'm stumped.
I have probably what you are looking for and I can take photos of it for you. The machine is a true copy of the Fortuna and the brand is a Nohab with a roller feed pressure fot, it splits everything.
Pär
Sweden
