Does any ine have any feedback on the Tandy" Leather Weld"? I have a project that needs gluing and don't have time to get Barge's or Master contact cement.
Does that stuff WORK?!!!!!
Please respond asap!!
pete
I have been using it, and I use it when it needs to be bonded better then contact cement.... is a bit thicker than Elmers white school glue, so i use a brush to apply it, I use pressure to hold the two pieces together and give it 20-30 minutes minimum to cure.... I like to give it over night, but after 20 munites I am able to go back working with it without it coming apart.... what seeps out the sides I roll off with my thumb, and go back to work on it.... I love it.... on anything you are bonding flesh side to flesh side where the flesh side is smooth.... you need to rough it up... especially with latigo..... Hope this helps
