Jfrancis
How Do You Adjust Stitch Width Singer 111G From Under Shaft Cover
Hi just wondering if anyone can help me please.
I own a SInger 111G and would like to adjust the stitch length.
The setup on mine is different and needs to be adjusted near the shaft just under the face plate cover near the balance wheel.
When you swing it open the shaft is visible and when you turn it the 2 screws below are visible.
Does anyone know the correct steps to alter the stitch length?
Thanks in advance.
The Singer 111G manual on page 12 has the same steps for changing stitch length as all the other 111 type machines I've come across - pressing a button in the machine bed and turning the hand wheel. Are you saying your machine does not have the button in the bed you press to change stitch length? It's seems very inconvenient having to get out the screw driver every time you need to change stitch length. The basic task is to shift/slide the two halves of the connector dovetail groove to change the offset between the two. A few photos for context and detail might really help in figuring this out.
Edited by Uwe
