Hi Everyone,
Here I am once again seeking your council. A problem has just come up with the dye on one of my holsters rubbing off. I dont think it is affecting the look of the holster but I dont want dye staining my customers and friends clothing. Please tell me what I am doing wrong in the dye process or what I can do to fix this very troublesome problem. Thank you very much.
John.
QUESTION..............JOHN.
1......WHAT BRAND OF DYE ARE YOU USING.
2......WHAT TYPE OF LEATHER ARE YOU DYING.
3......ARE YOU BUFFING UNTILL NO DYE RUBS OFF.
4......WHAT DID YOU USE AS A FINISH COAT.
A LOT OF QUESTIONS .....WILL GET YOU AMSWERS
Edited by Luke Hatley
1. I use fiebling's leather dye I think its alcohol based. (mahogany)
2. 6 to 7 ounce single shoulders
3. No, I have not been buffing until no dye rubs off, I rub in dye twice to get good coverage.
4. I use fiebings acylic resolene.
Thanks for your help, I will be happy to answer any other questions in order to fix this problem. I apologize in advance if I am doing something or not doing something to cause my own problem. I am absolutely still learning so much.
John.
I really need help with this. Please. :feedback:
Just my experience but Im not very experienced lol.
The feibings dye which is what I use also in full strength will take neer forever to get to stop rubbing off. I am not sure if you delute them or not but I delute mine about 50/50 with denatured alcohol (grab it at lowes or home depot cheap). I will do usually a couple of coats then let it completely dry. Then I buff it for a while. Then I oil it and then let it sit overnight to absorb the oil and dry. Most recommend 24hrs for the oil to set in so I try to hold to that but not allways.
Once that is done I buff it some more. Then depending on where I am at with my project Ill go ahead and seal it with what ever you plan on sealing with. I personally for my projects generally use either leather balm with atom wax or tan coat.
I usually do a couple of layers and LET IT DRY between layers. And not to thick either on the sealer or it doesnt work right.
Once that is done I usually do a thin layer of aussie wax or snoseal. Thats depends on the project though and is just my own thing,
