biker55
Finishing Work
hello folks, the couple of projects that I've done so far I've been using the satin sheen to coat it. does this protect the leather from the weather? or do I need to put a water proofer on it? and if I do need a waterproofer, do I use both? thanks
Is satin sheen same as resolene? I know resolene is the best to protect against water. Although it should be noted you can never make leather 100% waterproof, just more water resilient (which fades over time).
Edited by Ski
