TomG
Looking For 2" Buckles
I am in search of a couple of 2" solid brass, polished, square buckles.
I have checked OTB, Tandy, Springfield, Buckle Guy and Amazon. So far, all I can find are brass plated and/or roller buckles.
Does anyone have a source I can check out?
Thanks
http://www.bucklebox.co.uk/50mm-solid-brass-belt-buckle-2-inches-wide-50mm-3798-p.asp
http://www.ebay.com/itm/1-x-HEAVY-DUTY-SOLID-CAST-BRASS-SQUARE-BELT-BUCKLE-3-4-2-you-select-/191109753035?pt=UK_Crafts_Leathercraft_LE&var=&hash=item2c7f0768cb
http://www.ebay.com/itm/SOLID-BRASS-MILITARY-ROLLER-BELT-BUCKLE-Leathercraft-1-2-2-408-you-select-/191107929004?pt=UK_Crafts_Leathercraft_LE&var=&hash=item2c7eeb93ac
http://www.ebay.com/itm/HEAVY-DUTY-2-or-50-mm-2-Pin-Solid-Brass-Roller-Belt-Buckle-Leather-Craft-410-/201017504574?pt=UK_Crafts_Leathercraft_LE&hash=item2ecd93b33e
Use 50mm instead of 2" when you search for them. Most of the countries that make 2" belt buckles use the metric system. Granted only 4 countries in the world use something besides the metric system.
I have never ordered from any of the listed sellers so I can't vouch for them. Two of the links are for roller buckles but you may want to dig further into their inventory.
Edited by barehandcustoms
I have a couple here if you cant get them anywhere else.
PM me for cost style etc.
Cheers Trevor
"Way Down Under"
post-2565-0-65314400-1409089917_thumb.jp
Thanks Trevor and BareH... If I get them, I'll need them pretty quickly, so out of country won't work.
I've told my customer that we'll have to use the roller buckle I found on eBay here in the states.
Later
