Roger J
Cutting Leather At Angle To Create Retention Lip On Pouch?
Quite a mouthful I know, but this picture should help clear things up:
Notice that the leather of lid and body is cut at an angle to "lock" in place when closed.
I'm guessing that they probably use some type of press, and I don't think I could do this cleanly with just a knife.
Is there a special technique or affordable tool that would help one accomplish this?
my guess, and its only a guess is that the piece of leather was flat first and a round cut was made. He then wet moulded both pieces into a circle. The curve comes from the two pieces bending into that circle shape. So imagine a line and it is cut then both pieces are joined and molded, the angle where the two pieces meet will still be touching but the angle will be changed. I could be wrong, it may have been moulded then cut. I would email him and ask him, he may be incline to give away the process.
Edited by DavidL
You can put it on edge and cut it with a band saw.
Tree Reaper has the right idea.
I would first mold the pocket, half circle, pouch, . . . whatever you call it.
Add the fastener and all the snaps, . . . glue and sew it to it's base, . . . making the thing all done except for the final cutting.
Then I would stain the thing and get at least one good coat of resolene on it, . . . making sure it is dry as can be.
Then I would cut out the lid, . . . but I would use a coping saw, . . . but that is me, . . . band saws are too fast for my reflexes.
You could then touch up the edges of the cut pieces with dye and more resolene.
Good luck, . . . looks like an interesting project.
May God bless,
Dwight
Thanks guys.
Bandsaw: not a bad idea as the blade goes only in one direction and they do make 1/8" blades with 32 TPI. All I have right now are 1/2" 3TPI rip blades...it would be a bit rough.
Coping saw: I had thought the back and forth movement of the blade might give a ragged edge to the leather. I'll see if I can adapt some ultra fine scrollsaw blades to fit my coping saw.
Might end up doing that, but it would feel kinda weird, like asking a chef for his secret recipe.
