How to Lace rear jockeys
  • Please log in to reply
10 replies to this topic
#1 tmroper
tmroper
    Member
  • PipPip
  • 17 posts
  • Leatherwork Specialty:custome saddles & silver
  • Interested in learning about:braiding
  • How did you find leatherworker.net?:internet
Posted 04 June 2009 - 11:32 PM
I usually put a frog on my rear jockeys because I have never been satisfied with my attempts at lacing them together. I would appreciate any advice on completing the task including what size holes to punch, how far btwn holes, what width lace.
Thank you
#2 tmroper
tmroper
    Member
  • PipPip
  • 17 posts
Posted 06 June 2009 - 12:18 AM
hopefully someone has some experience with lacing the jockeys together.
#3 superchute
superchute
    Ambassador
  • Ambassador
  • PipPip
  • 209 posts
  • Gender:Male
Posted 06 June 2009 - 08:37 AM
well Im not the one to show you how but some day my take a little longer as they guy that can do it may be working or there battery die on there lap top. Im shere one will be by so to help
Russ
#4 Bob
Bob
    Member
  • PipPip
  • 379 posts
  • Gender:Male
  • Interests:hunting and nice guns
  • Leatherwork Specialty:Saddle Maker
Posted 06 June 2009 - 09:23 AM
Tmroper, I usually braid them together. The process is quite simple.
It's best if you don't edge the jockeys at the top.
use a compass and mark 3/4 inch from the edge where you going to lace.
set the compass at 3/8 inch and mark where you want the holes to be
use a #8 osborne punch , or 1/4 inch and punch holes
cut lace 5/16 wide and 2oz thick, I use latigo, it stands up the best and don't stretch much
You may need 7-8 feet
the lace is started in the middle, equal parts on both sides, at the outside edge of the jockeys
you have to use the end hole 3 times in the beginning
the other holes are used twice
the lace is weaved back and forth, over and under itself.
once your finished, lay the piece upside down on the granite and tap with a large face hammer to flatten the laces.
helpful hints
use saddle soap on the latigo strings
some guys bevel the edges, i don't.
you don't want any spaces between the laces, be sure the use the hole spacing for that size lace.
If i could find my camera this morning I'd post a picture for you.
i learned this from another saddle maker and I'm not sure if it's in a book somewhere. Chances are it is.
Hope this helps
Bob Goudreault
www.kamloopssaddlery.com
#5 heath
heath
    Member
  • PipPip
  • 21 posts
  • Gender:Male
  • Leatherwork Specialty:saddles
  • How did you find leatherworker.net?:stumbled on it
Posted 27 June 2009 - 05:49 AM
Before you lace them together I was taught to lace the skirts together with waxed thread. I put the holes close to the edge and 3/4- 1" apart. This tends to keep the braiding from coming loose over time, as the skirts will be pulling on the thread not the lacing. I also braid them with two pieces of lace instead of on. I can't describe the method but the next time I do one I'll take a pic.
Heath
#6 Tosch
Tosch
    Member
  • PipPip
  • 123 posts
  • Gender:Male
  • Leatherwork Specialty:I am a recreational rider seriously interested in saddle and saddle tree construction.
Posted 28 June 2009 - 01:11 AM
I would not know how to do it.
But obvioulsly the saddle maker who wrote an tutorial "some" time ago in Western Horseman Magazine knew it. So here it goes.
Hope it helps.
Tosch
Edited by Johanna, 28 June 2009 - 11:24 AM.
removed attachment pending owner's permission to post it here
#7 Saddlebag
Saddlebag
    Member
  • PipPip
  • 385 posts
  • Leatherwork Specialty:Saddle, tack repair
  • Interested in learning about:everything to do with leather
  • How did you find leatherworker.net?:surfing
Posted 02 August 2009 - 07:46 PM
Bob Land at Okanagan Saddlery does beautiful rawhide lace work on saddles.
#8 BobLand
BobLand
    New Member
  • Pip
  • 7 posts
  • Gender:Male
  • Leatherwork Specialty:Saddle maker, Rawhide braider
  • Interested in learning about:All aspects of leather work
Posted 02 August 2009 - 11:31 PM
These photos show one of my students as she makes a sample piece of Appliqué braiding prier to doing a fork cover on her saddle
Photo I shows hole spacing, this must be set precisely to the width & thickness of the lace you are going to use.
Photo 2 showing back side of lace pattern
Photo 3 starting lace into hole to go to front side
Photo 4 showing front side of lace pattern
Photo 5 shows the path of the string on the left going to the right
Photo 6 shows the path of the string on the right going to the left
Photo 6 shows the finished braid pattern
Please bare with me as this is my first attempt at uploading photos hopefully they will appear
Bob
www.okanagansaddlery.com
#9 BobLand
BobLand
    New Member
  • Pip
  • 7 posts
  • Gender:Male
Posted 02 August 2009 - 11:46 PM
I will add the photos as soon as I can figure out how to upload to this site, in the meantime tmroper if you or anyone else, want to email me via my web site I will send you the information along with the photos by return email.
Bob
#10 BobLand
BobLand
    New Member
  • Pip
  • 7 posts
  • Gender:Male
Posted 03 August 2009 - 01:41 PM
These photos show one of my students as she makes a sample piece of Appliqué braiding prier to lacing a back jockey on her saddle
Photo I shows hole spacing, this must be set precisely to the width & thickness of the lace you are going to use.I usually use 1.5oz Rawhide lace 1/4 inch wide (it will take 6ft of lace to make 5 inches of Appliqué braid)
Do not edge the jockeys at the top,
Make a compass mark 1/4 inch in from edge of jockey
Mark holes on 7/16 centers along this line, (I use a oval !/8 inch hole punch, with a very thin wall so as not to spread the top of the hole)
Burnish the edge as per. your normal way up to where the lacing starts.
Now stitch the edges of the jockeys together with thread & needle, making sure that the holes are directly across from each other.
Attached File  1.jpg   106.38KB   509 downloads
Make sure the 6 ft Rawhide lace is well tempered and that you have saddle soaped it well.
You are now ready to start lacing.
Attached File  2.jpg   182.04KB   692 downloads
Attached File  3.jpg   187.81KB   725 downloads
Attached File  4.jpg   198.05KB   638 downloads
Attached File  5.jpg   154.64KB   526 downloads
Attached File  6.jpg   163.24KB   484 downloads
Photo 7 shows the path of the string on the left going under the string next to it & continuing to the hole on the left.
Attached File  8.jpg   198.03KB   512 downloads
Bob,
www.okanagansaddlert.com
  • Attached File  7.jpg   179.29KB   388 downloads
#11 lostcowhand
lostcowhand
    New Member
  • Pip
  • 1 posts
Posted 08 November 2015 - 08:12 PM
There are several valuable methods of lacing rear jockeys in this thread, but this is the simplest tutorial I have found yet.
www.youtube.com/watch?v=xn9l_dCJDEU
Sean
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
