Leatherworker.net: Treating the inside of a holster - Leatherworker.net
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   carljc72 Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:Concealed Carry Gun Leather, Guns
  • Leatherwork Specialty:gun leather
  • Interested in learning about:holster and belt making
  • How did you find leatherworker.net?:another forum
Posted 19 June 2009 - 12:14 AM
Has anyone had a customer ask what they could use to treat the inside of their holster to aid in the smoothness of the draw/to help it break in faster? And what do you recommend? The inside of this particular holster was dyed black with Fiebings and then slicked with Gum Trag. It was Wickett and Craig 8oz shoulder if this helps. It was finished with Resolene. :whatdoyouthink:
Thanks, Carl
Carl Collins
www.ccholsters.com
#2 User is offline   woolfe Icon
  • Member
  • PipPip
  • Group: Members
  • Leatherwork Specialty:none
  • Interested in learning about:leatherworking
  • How did you find leatherworker.net?:google
Posted 19 June 2009 - 02:02 AM
Thanks, Carl
I haven't had that asked.
Anything that would help to break the holster in also threatens to challenge the integrity of the holster. Retension is the primary concern and if they break it in to fast then it will be worn out. I would stress normal use is recommended to assure the long life of the holster. The customer should attempt to break the holster in by wearing/drawing from it around the house before wearing it in public.
Other holster manufactureres have suggestested other things such as using plastic bags around the gun to speed this process up. I do not recomend this simply because their is no way to know the exact outcome.
#3 User is offline   TwinOaks Icon
  • Ambassador
  • PipPipPipPip
  • View gallery
  • Group: Ambassador
  • Country:
  • Gender:Male
  • Interests:all of it.
  • Leatherwork Specialty:Too interested in everything to 'specialize' in anything
  • Interested in learning about:Adding some color
  • How did you find leatherworker.net?:Yellow Pages :)
Posted 19 June 2009 - 07:24 AM
I've recommended wraping in a plastic bag because it gives you a very precious few thousandths of an inch clearance. I do this because wet molding to the actual gun and letting the leather dry on the gun, tends to make a very tight holster. Retention is great. Marvelous. Couldn't shake the dang gun out. Couldn't draw it either.
As far as slicking up the interior of the hoslter.....I use teflon dry lubricant spray. Don't soke the leather with it, just hit the spots that are rubbing the most. That'll help with the draw and hopefully keep the user from stretching the holster while 'breaking it in".
Mike D.
"Lazy spider lets dinner guest wreck home"
TwinOaks Leather Website
#4 User is offline   Lobo Icon
  • Member
  • PipPip
  • Group: Contributing Member
  • Gender:Male
  • Leatherwork Specialty:holsters, accessories
  • How did you find leatherworker.net?:web search
Posted 19 June 2009 - 07:31 AM
I have had this come up from time to time. Usually this involves customers who have not experienced a holster closely fitted to a specific handgun, rather than the more generic fit of some products on the market.
As Woolfe has pointed out, many products (spray silicone, mink oil, and others) that might be tried can have a tendency to overly soften the leather, thus overcoming the integrity of the molding process.
I like to point out to customers that the close fitting is beneficial in additional retention qualities as well as limiting movement of the handgun within the holster during use (which I believe to be the primary cause of holster wear to the handgun finish). Should the customer persist in wanting something to slick up the interior surfaces, I suggest using waxed paper wrapped around the weapon and repeated insertions and extractions, which transfers some dry wax to the leather surfaces. It is tedious to do, and one will go through a lot of waxed paper, but it does work to a degree and does not transfer anything harmful to the finished leather.
Lobo Gun Leather
serious equipment for serious business, since 1972
www.lobogunleather.com
#5 User is offline   Shorts Icon
  • Leatherworker
  • PipPipPip
  • Group: Members
  • Gender:Female
  • Leatherwork Specialty:Modern gun holsters & accesories
Posted 19 June 2009 - 08:04 AM
I suggest the plastic bag method to my customers and I use it myself. I hear the wax paper method is good as well.
I send out tight holsters. Fresh Resolene adds to the strength of the sticky. The plastic tempers the leather to just the right fit.
Monica Kuehn Leather
Don't Mess with Texas Women
Stuff for sale
#6 User is offline   carljc72 Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 19 June 2009 - 05:05 PM
Thank you everyone for your replies. This is similar to the information that I originally told him and I will call to reinforce it. I did not know about the waxed paper and will forward that info on as well. Again, thanks to all who have traveled before me and are willing to share. :You_Rock_Emoticon:
Carl Collins
www.ccholsters.com
#7 User is offline   TwinOaks Icon
  • Ambassador
  • PipPipPipPip
  • View gallery
  • Group: Ambassador
  • Country:
  • Gender:Male
Posted 19 June 2009 - 05:12 PM
To clarify, the lubricant I use is a dry teflon lube. You spray it on, and a teflon film remains. One source is RemDry, a gun lube, and I think "P'Blaster" makes one as well.
Mike D.
Share this topic:
Page 1 of 1
Similar Topics Collapse
  Topic Forum Started By Stats Last Post Info
New Replies Icon Attachments Cowboy Cuffs In The Works Collars, Cuffs, Leashes and Leads Cowboy316 Icon
  • 2 Replies
  • 175 Views
New Replies Icon Attachments Sewing Leather With A Drill Press How Do I Do That? Dwight Icon
  • 2 Replies
  • 687 Views
New Replies Icon Attachments need a special dog collar made
Can anyone offer to make it for me
Help Wanted 1234567 Icon
  • 5 Replies
  • 634 Views
Locked Topic Icon Who NOT to buy from...
Zack White aka: Eleatherworks
Suppliers Sharpshooter Icon
  • 14 Replies
  • 1,112 Views
*New Replies Icon need a leatherworker
hw
Help Wanted Guest_LM
  • 3 Replies
  • 560 Views
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
