cleaning glue brushes: white glue and contact cement
  • Please log in to reply
12 replies to this topic
#1 esantoro
esantoro
    Leatherworker.net Regular
  • PipPipPipPip
  • 2,259 posts
  • Gender:Male
  • Leatherwork Specialty:briefcases, satchels, handbags, belts, journals
Posted 23 March 2008 - 04:26 PM
What's the best solvent to use for cleaning glue brushes that have been used to spread both white glue and contact cement. Because I have it for my gas lamp, I have been using denatured solvent alcohol. It seems to work as long as the brushes are kept in the solvent, but when I take them out, dry the off, and let them sit, they harden up again. I'll try rinsing the brushes off in very hot water.
My next guess is to use turpentine, but the denatured solvent alcohol doesn't pose a problem with fumes, which I'm not sure is the case with turpentine
Thanks,
Ed
#2 Rawhide
Rawhide
  • PipPipPipPip
  • 1,294 posts
  • Gender:Male
  • Interests:My family<br />Leatherwork (obvious one)<br />Fishing<br />
  • Leatherwork Specialty:None as of yet.
  • Interested in learning about:How to draw (figures & patterns) from scratch
Posted 23 March 2008 - 04:57 PM
You may try cement thinner. Barge makes one and I'm sure other manufacturers have it as well. You may also try naphtha, but if denatured alcohol doesn't work, chances are naphtha won't either.
Marlon
Marlon
#3 barra
barra
    Sewing Machine Moderator
  • PipPipPip
  • 838 posts
  • Gender:Male
  • Leatherwork Specialty:tack, saddlery, Harness, Traditional Australian Stock Saddles, Upholstery,Motor/Aviation trimming
Posted 23 March 2008 - 05:17 PM
when we cover aircraft panels we use toluene to clean brushes.
personally I'd like to just dispose of the brushes after the job as they are cheap and a safer option to avoid chemicals all together.
At home in the workshop my adhesives like latex and PVA are in plastic sauce/ketchup bottles with the little cap attached. I find these make for easy application. I then use a scrap of leather or scrap shearling as a spreader. when done I dispose of it. No mess, no fuss. The scrap leather applicator can be used just like a brush to apply contact cement straight from the can/
Barra
Edited by barra, 23 March 2008 - 05:21 PM.
"If You're not behind the Troops, please feel free to stand in front of them"
#4 Beaverslayer
Beaverslayer
    Ambassador
  • Ambassador
  • PipPipPipPip
  • 1,984 posts
  • Gender:Male
  • Interests:Ancient History
    Native Artwork
    Website Design
  • Leatherwork Specialty:Custom Clothing Design/Hand Lace
  • Interested in learning about:Rawhide Braiding
Posted 23 March 2008 - 08:06 PM
I'm with Barra on this one, I'll use the brush until the job is done then into the waste can it goes. I'll buy a few bags of them at the dollar store, that way the cost is greatly reduced. There's no need to use an expensive brush to apply glue with.
And the smell of some of those solvents, and the thought of what they are doing to your skin...YIKES
Ken
Beaverslayer Custom Leather
Wearable Works of Art
https://www.facebook...erCustomLeather
#5 bcurrier
bcurrier
    Member
  • PipPip
  • 212 posts
Posted 25 March 2008 - 01:50 PM
I save the fake plastic credit cards they stick in credit card solicitation mailings to use as glue spreaders. They work great and they're free.
Bill
#6 Rawhide
Rawhide
  • PipPipPipPip
  • 1,294 posts
  • Gender:Male
Posted 25 March 2008 - 02:02 PM
Bill
This is what I do. Plus I keep hotel cards as well, because the card contains your personal information until the next customer comes along and needs a key, then they erase it and recode it with that person's info. After learning this, I now keep my hotel cards and use them for spreading glue and cut them up when they aren't useable anymore.
Marlon
Marlon
#7 moon
moon
    Member
  • PipPip
  • 69 posts
  • Leatherwork Specialty:knife sheaths
  • Interested in learning about:improving my meager skills
  • How did you find leatherworker.net?:knifenetwork forum
Posted 25 March 2008 - 02:07 PM
Another vote for throwing them away when finished.A package of about 50 is about $ 2.00 at Harbor Freight.Moon
#8 esantoro
esantoro
  • PipPipPipPip
  • 2,259 posts
  • Gender:Male
Posted 25 March 2008 - 06:13 PM
I like the idea of using plastic cards as spreaders. thanks for the replies.
ed
#9 Beaverslayer
Beaverslayer
    Ambassador
  • Ambassador
  • PipPipPipPip
  • 1,984 posts
  • Gender:Male
    Native Artwork
    Website Design
Posted 31 March 2008 - 03:35 AM
I'm not sure if this works with Barges or the smelly contact cement, but it woks real good for the water based contact.
When you get a big blob of glue stuck to your brush, and it's not working as well as you'd like. Do this while the blob is still somewhat wet.
Attached File  DSCF0787.JPG   128.87KB   28 downloads
Take a piece of scrap pigskin and fold it over the end of the brush. Squeeze tightly, and pull the brush away from the pigskin. You may have to do this 2 times.
Attached File  DSCF0788.JPG   71.7KB   29 downloads
Here's how clean it came after 2 pulls.
Attached File  DSCF0789.JPG   89.18KB   29 downloads
#10 esantoro
esantoro
  • PipPipPipPip
  • 2,259 posts
  • Gender:Male
Posted 21 April 2008 - 02:50 PM
For a while I had been putting the brushes, once I am finished with them, into a cup of water that had reached the boiling point. The problem with this is that I was leaving them there until cleanup at the end of the day. Now I've decided to put the brushes in the hot water when the glue is still wet, swish and dab the brush around a bit, then remove it and put it on my glue tray. By leaving the brushes in the hot water, I think I was allowing the glue to return to the bristles and harden, especially as the water cooled.
Using solvent is just too expensive, and I can do without any unnecessary fumes.
Anyone have a good source for cheap brushes, other than sales at Harbor Freight? I'll try the dollar stores. Next time I see them for a steal at Harbor Freight, I'm buying 200 or so.
Ed
#11 waywarddreams
waywarddreams
    New Member
  • Pip
  • 6 posts
  • Gender:Female
  • Interested in learning about:Everything, anything. I want techniques to add to my arsenal.
Posted 21 April 2008 - 03:00 PM
I may be new to leather, but certainly not to using cheap brushes for glue. My record was 30 stiff bristled brushes of unknown origin for a whopping $1.50
There's a fine line between a "hobby" and a "mental illness"
#12 HandyAndy
HandyAndy
    Member
  • PipPip
  • 41 posts
  • Leatherwork Specialty:Novice
  • How did you find leatherworker.net?:Google
Posted 21 April 2008 - 06:58 PM
Bill
You can cut out guitar picks from them too :P
#13 Tina
Tina
  • PipPipPipPip
  • 1,842 posts
  • Gender:Female
  • Interests:If it smells leather I'm all interested:-)
  • Leatherwork Specialty:Being "arty" and do things a wee bit different:-)
  • Interested in learning about:Everything. I'm hungry:-)
  • How did you find leatherworker.net?:searching the net
Posted 21 April 2008 - 07:39 PM
I got tired of wasting brush after brush and I found out that turpentine gets my brush "clean" from contact cement.
"He who works with his hands is a laborer.
He who works with his hands, and his head is a craftsman.
He who works with his hands, and his head, and his heart, is An Artist"
http://vildkorpens-l....deviantart.com
http://tupali.deviantart.com/
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
