glue leather to wood
  • Please log in to reply
7 replies to this topic
#1 DG Leather
DG Leather
    Member
  • PipPip
  • 193 posts
  • Leatherwork Specialty:In learning process and exploring
  • Interested in learning about:lots
  • How did you find leatherworker.net?:I am just changing my account from ganonymous
Posted 10 September 2009 - 11:36 AM
I a m wondering what is the best way to adhere leather to wood with an adhesive...
Also is there a type of wood that would work best?
I am wanting to use normal plywood(not particle board nor chip board).
#2 Somawas
Somawas
    Member
  • PipPip
  • 170 posts
  • Gender:Male
  • Leatherwork Specialty:I'm starting to think its bags
  • Interested in learning about:tooling
  • How did you find leatherworker.net?:webring
Posted 10 September 2009 - 01:36 PM
How permanent do you want the bond to be?
#3 DG Leather
DG Leather
    Member
  • PipPip
  • 193 posts
Posted 10 September 2009 - 02:24 PM
I want the adhesive to last as long as possible......never to be removed!!!!
I am as sure about this as I am that death will come to us all..lol
#4 joet
joet
    Member
  • PipPip
  • 205 posts
  • Gender:Male
  • Interests:Anything and everything leather, except saddles. I don't do saddles or shoes.
  • Leatherwork Specialty:pictures, billfolds, checkbook covers and a little of other things
  • Interested in learning about:Figure carving
Posted 10 September 2009 - 04:00 PM
I've used contact cement with no problems. I've never tried wood glue, but I'm sure that would work also, can any one else add to that?
#5 cajun
cajun
    Member
  • PipPip
  • 44 posts
  • Gender:Male
  • Leatherwork Specialty:general
  • Interested in learning about:all types
  • How did you find leatherworker.net?:on the internet
Posted 10 September 2009 - 05:23 PM
I make alot of leather picture frames and use 3M - NF30 and it does a great job.
Regards,
Bill Parrie
#6 bryanma71
bryanma71
    New Member
  • Pip
  • 6 posts
  • Leatherwork Specialty:Shoes and Braiding
  • Interested in learning about:everything
  • How did you find leatherworker.net?:google
Posted 10 September 2009 - 06:34 PM
I'm in the shoe bussiness and when I have to change a last I glue leather to it, using a contact glue. In order to get a good bond, you have to rough up the back side of the leather and then apply two coats of glueto the leather (let the first coat dry and then add the second coat) and one coat to the wood. After that you put the leather on your wood and apply good presure. I use a shoemakers hammer. It has a smooth face so it wont scrape up the leather. I have a last from 1923 that was built up like this and the leather is still holding.
#7 hidepounder
hidepounder
    Leatherworker.net Regular
  • PipPipPipPip
  • 1,716 posts
  • Gender:Male
  • Interests:"Roping, Riding & Sliding"
  • Leatherwork Specialty:Western floral tooling
  • How did you find leatherworker.net?:accidental browsing
Posted 10 September 2009 - 06:48 PM
If it was me I would use Barge (old formula) or Masters contact cements. Either will hold. From what I've been hearing about WeldWood it sounds like it's as good or better than Barge or Masters.
Bobby
Edited by hidepounder, 10 September 2009 - 06:49 PM.
Posted Image Posted Image Posted Image
#8 Somawas
Somawas
    Member
  • PipPip
  • 170 posts
  • Gender:Male
Posted 10 September 2009 - 07:05 PM
Since it is to be as permanent as possible, I have two more suggestions: Real epoxy (not the five minute stuff, boatbuilder's epoxy) or gorilla glue. I've used all sorts of materials with real epoxy, and you bond almost anything to almost anything for almost ever with it. It's downside is that it is not the easiest stuff to work with, you MUST wear rubber gloves to work with it, and it is expensive. You're probably better off using a good contact cement. But epoxy will be pretty much perpetual.
Similar Topics Collapse
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
