Hair Blade Tool - Right way? Wrong way? No Way?
  • Please log in to reply
9 replies to this topic
#1 Crystal
Crystal
    Leatherworker.net Regular
  • PipPipPipPip
  • 1,041 posts
  • Gender:Female
  • Leatherwork Specialty:Making scrap!
  • Interested in learning about:Everything
  • How did you find leatherworker.net?:web surfing
Posted 17 April 2008 - 09:12 PM
Hi All-
I am attempting project no 2 and wanted to add some texture with a Craftool Hair Blade that I just got. I am not happy with how any of my test pieces have come out. Seems too "scratchy" not enough texture. I don't want a lot of definition - just the impression of some hair. Chuck it and use something else? Keep the tool and chuck the operator? Pretend the subject is wet and keep the whole project smooth? Any tips are greatly appreciated!
Crystal
#2 ClayB
ClayB
  • PipPipPipPip
  • 1,831 posts
  • Gender:Male
  • Interests:Love to explore new country, watching wildlife, a little hunting, horseback riding and a lot of leather carving.
  • Leatherwork Specialty:extreme embossed figure carving
  • Interested in learning about:new carving and coloring techniques
  • How did you find leatherworker.net?:founding member
Posted 17 April 2008 - 09:56 PM
Hi All-
Crystal
Hi Crystal,
This is just another thing that will take some practice. A few tips on using the hair blade. First, the leather should be pretty dry when you use it. Try using different amounts of pressure on the knife to see if you want deep cuts that really show up, or shallow cuts that just give a hint of hair. I was taught that summer coats of hair on things like a horse shouldn't even be haired as they look smooth and sleek without hairing. Second, use short strokes with the knife. I dont know what you are trying to hair, but most hair is going to be pretty short on animals other than manes and tails. Look at pictures of the animal you are carving and try to follow the hair direction. There will be a lot of direction changes. By making the hair in short strokes, it's easier to make the direction changes appear natural. You can also give hair texture with a lined tool like a beveler by just dragging it across the leather, but again, short strokes and pay attention to direction changes. You can also "draw" hair on an animal with a pointed modeling tool or a sewing awl or needle.
If none of this helps, post a picture of what you have done so far and what you don't like and we can try and give you some ideas.
Clay
#3 Crystal
Crystal
  • PipPipPipPip
  • 1,041 posts
  • Gender:Female
Posted 17 April 2008 - 10:13 PM
Hi Crystal,
Clay
Hi Clay - Thank you. I haven't tried it on my piece - just on some scraps. The outside edges seem to catch more than the inside blades and I am getting light centers and deeper outsides from the 4 or so edges on the tool. I am trying to keep it pretty plumb and using short strokes like you mentioned. I may just need to do more practice. I like your other suggestions - I may put this techinque on the back burner and see if I can get somewhere close to what I want without it.
Thanks again!
Crystal
#4 Dale
Dale
    Member
  • PipPip
  • 103 posts
  • How did you find leatherworker.net?:e-mail message from you!
Posted 17 April 2008 - 10:39 PM
I never have like the Craftool hair blades. One day they'll change the curve on the face from concave to convex and it just may work! I think Clay gives two of the best alternatives I've found -- use a lined beveler or a needle (different sizes of glovers needle work well).
Dale Hietala
www.moonlightartstudio.com
#5 Rawhide
Rawhide
  • PipPipPipPip
  • 1,294 posts
  • Gender:Male
  • Interests:My family<br />Leatherwork (obvious one)<br />Fishing<br />
  • Leatherwork Specialty:None as of yet.
  • Interested in learning about:How to draw (figures & patterns) from scratch
Posted 17 April 2008 - 10:42 PM
Here's the Peter Main way. (man I learned a lot from him).
Fisrt strop your hair blade, yes, strop it. Using rouge on leather is fine. Pick out the leftover rouge from between the "hairs".
Next the technique depends on the animal or person you are carving. If it's short hair, pull the blade in short bursts. If it's long, use long strokes.
For a little more definition, take your hair blade tool and hold it like a pencil (if you have it in a swivel knife, take your index finger out of the yoke and hold it like a pencil),
now using really short arching moves, almost choppy, go over the entire hair area.
Marlon
Marlon
#6 Crystal
Crystal
  • PipPipPipPip
  • 1,041 posts
  • Gender:Female
Posted 17 April 2008 - 10:47 PM
Thanks, Dale. I am learning fast that no tool is perfect.
Crystal
#7 Crystal
Crystal
  • PipPipPipPip
  • 1,041 posts
  • Gender:Female
Posted 17 April 2008 - 10:51 PM
Marlon
Thanks, Marlon. If I am understanding this - strop it so I am taking all the edges through the rouge - not like a swivel knife (on edge). Right?
#8 ferret
ferret
    Member
  • PipPip
  • 200 posts
  • Gender:Male
  • Leatherwork Specialty:getting it wrong
  • Interested in learning about:getting it right
Posted 18 April 2008 - 02:38 AM
There's a cheap DIY alternative to hair baldes and bevellers, all you need to make them is a small hacksaw and a mallet.
Politicians are like nappies, both should be changed regularly for the same reason.
#9 Rawhide
Rawhide
  • PipPipPipPip
  • 1,294 posts
  • Gender:Male
Posted 18 April 2008 - 06:53 AM
You are exactly right. Using leather is better as it will get between the "lines"
Marlon
Edited by Rawhide, 18 April 2008 - 08:24 AM.
Marlon
#10 Crystal
Crystal
  • PipPipPipPip
  • 1,041 posts
  • Gender:Female
Posted 18 April 2008 - 08:09 AM
Hubby's going to get nervous when I start breaking into his tool box. :)
Crystal
Similar Topics Collapse
  Topic Forum Started By Stats Last Post Info
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
