Setting Snaps...
  • Please log in to reply
20 replies to this topic
#1 Sixer
Sixer
    Member
  • PipPip
  • 348 posts
  • Gender:Male
  • Interests:Guns, Reloading, Leatherwork...
  • How did you find leatherworker.net?:a member suggestion from a gun forum
Posted 11 January 2011 - 12:57 PM
These little things are driving me nuts! Im using Line 24, Line 20, Segma, and Glove snaps for various projects. Right now I just have the set-all kit that comes with the little cheap anvils and setting tools. I'm using a good solid surface, but can't set a good snap to save my life.
Is there an easier way to set snaps that doesn't cost a couple hundred dollars?
#2 Art
Art
    Marketplace and Adult Area Moderator & Sewing Machine Expert
  • PipPipPipPip
  • 3,827 posts
  • Gender:Male
  • Interests:Knifemaking, Gunsmithing, Machining, Sharpening
  • Leatherwork Specialty:Gunleather, MC, BDSM & Fetish gear
  • How did you find leatherworker.net?:Johanna
Posted 11 January 2011 - 01:50 PM
Hi ???
Pres-N-Snap
$110
Works
http://www.rochfords...ener/index.html
Art
#3 mountain man
mountain man
    Member
  • PipPip
  • 46 posts
  • Gender:Male
  • Interests:Hunting, Fishing, Leather work, Wood Working
  • Leatherwork Specialty:All
Posted 11 January 2011 - 03:03 PM
what oz is your leather
Calvin Deeds
#4 Sixer
Sixer
    Member
  • PipPip
  • 348 posts
  • Gender:Male
Posted 11 January 2011 - 03:41 PM
Hi ???
Pres-N-Snap
$110
Works
Art
Thanks for the link Art! I could probably swing $110 for something like that, but I'll need to sell a few more holsters first :)
Mountain Man - I'm using anything from 7/8 oz 3/4 oz Herman Oak.
Edited by Sixer, 11 January 2011 - 03:42 PM.
#5 Lwleather
Lwleather
    Member
  • PipPip
  • 77 posts
  • Gender:Female
  • Interests:Horses, horses, horses, oh and leather!
  • Leatherwork Specialty:Chaps and Chinks
  • Interested in learning about:Tooling
Posted 14 January 2011 - 10:34 AM
CS Osborne makes a snap setter that I use. It's simple and pretty hard not to get them set. # 230-SET. I bought mine from The Hide House in San Dimas. It was around $13.00. Good luck.
Lisa
www.lwleather.com
#6 Chief31794
Chief31794
    Leatherworker.net Regular
  • PipPipPipPip
  • 1,614 posts
  • Gender:Male
  • Interests:Leather Work, Music, Grandkids.
  • Leatherwork Specialty:Western Floral Carving, Lacing
  • Interested in learning about:Leather Craft
  • How did you find leatherworker.net?:Google Search
Posted 14 January 2011 - 02:30 PM
I use the press that Tandy sells (about $120 if you are an elite member, course then you have to buy a set of dies for the Line 20 Snaps, the Line 24 snaps, Rivets, etc, they ain't cheap), while I know you said you didn't want to spend a couple of hundred bucks, if you do a lot of these it's worth the money. They produce absolutely perfect connections every time and the resulting "curls" where the post is rolled back is perfect and looks very professional. I highly recommend them.
Ken
"Life's too short to carry ugly leather"
#7 lazybum
lazybum
    Member
  • PipPip
  • 124 posts
Posted 14 January 2011 - 09:18 PM
Just wondering if anyone tried the vice grip pliers from ohiotravelbag? (T-1239). It looks like they work similar to the press n snap.
Its pretty cheap, costs around 50 bucks including the line 24 dies. Im thinking of ordering one
Edited by lazybum, 14 January 2011 - 09:19 PM.
#8 reddevil76
reddevil76
    Member
  • PipPip
  • 384 posts
  • Gender:Male
Posted 15 January 2011 - 01:19 AM
I am using the Tandy kit you mentioned and have no problems currently. (is it the one which the anvil is flat, with four concave holes in it?http://www.tandyleatherfactory.com/search/searchresults/8105-00.aspx?feature=Product_2&kw=setter+snap )
May I ask, beside a good surface, did you insert a piece of solid metal directly beneath the snap, between layers of leather? (assuming you couldn't always get the anvil in)
I always keep a 1"X1" piece of steel handy, which I use beneath rivets or snaps when I am setting them, if the provided anvil does not fit (small coin pouches). And I tend to use the flat rivet more than dome head (line 24)
Also to take note, if the rivet side's head is dome, you would use the concave side of the anvil. If you are using the flat head rivet to set the snap, you should use the flat side of the anvil.
Starting out, I have once mistakenly used the concave anvil to set a flat head rivet and it wouldn't set correctly. I am thinking if that could be your situation.
Edited by reddevil76, 15 January 2011 - 01:27 AM.
#9 RobDude30
RobDude30
    Member
  • PipPip
  • 160 posts
  • Gender:Male
  • Leatherwork Specialty:None
  • Interested in learning about:Belts, holsters, card holders, wallets
Posted 15 January 2011 - 07:46 AM
I, too, use the Tandy kit you mentioned with good success as I only set a few snaps now and then. One other tip I can add is to make sure that you rotate the tool around in a circular motion as you tap the rivet several times. Don't hit it too hard either or you will deform the snap and make it very hard to clasp together. I use a medium weight rawhide mallet and tap fairly lightly. As the others have said, if you plan to set a lot of snaps, the good tools are probably money well spent.
#10 Relly
Relly
    Member
  • PipPip
  • 30 posts
  • Gender:Male
Posted 14 March 2011 - 12:22 AM
I was buying the line 24 snap kits for $10 each, and here is what I learned:
You can get bags of 100 snaps relatively cheap. Brass is particularly cheap, but looks really nice.
Once you have the snap anvil and setter, setting the snaps by hand is relatively easy with practice.
A couple good, solid hits with a light rubber-headed hammer will do the job.
Line 24 snaps are for 5-7 ounce leather, which is roughly 2 to 2.75mm thick.
If the leather is TOO THICK, the snaps won't form or hold properly.
If the leather is TOO THIN, you will deform the snaps trying to get them together.
Different snaps are meant for different thicknesses of leather.
I use a 1/2-ton hand press (dirt cheap, $40) and the snap die and setter from one of the kits.
It's quicker than the hammer and less noisy for my downstairs neighbor :)
You can measure thickness with a pocket caliper like this one:
Home Depot Store SKU # 501570
(Needs lubrication, I suggest any except WD-40)
Reducing the thickness of leather is called skiving.
The Tandy super skiver requires practice to use, but it's $10.
A round knife can be used to skive, but it requires a LOT of practice and sharpening skills.
(That's where I am at, trying to learn how to use it).
I am still new to this hobby, I hope that my tips help you.
Relly
#11 Dwight
Dwight
  • PipPipPipPip
  • 2,471 posts
  • Gender:Male
  • Interests:Church Pastor, Shooter, Leatherworking, Hunting, making most anything for the first time (yeah, I get bored easy)
  • Leatherwork Specialty:gun leather
  • Interested in learning about:working with leather
  • How did you find leatherworker.net?:from 1911.com
Posted 14 March 2011 - 07:39 AM
With time, . . . a little practice, . . . a couple ruined projects, . . . and a small box full of wasted/broken/folded/spindled snaps, rivets, etc, . . . you can learn to use the tools sold at Tandy's.
For line 24 snaps, . . . go to Hobby Lobby (they have it on line also, but you'll have to call their 800 number to order it as it is hard to find in that Pakistani web site of theirs), . . . they sell a blue handled snap setter for around $23.00, . . . it is head and shoulders above the Tandy tool. You'll find it on the wall where they sell their sewing tools (scissors, tapes, needles, rotary cutters, etc).
The SKU number for that tool is 733006. They also have another hand tool in the same price range that is supposed to do smaller snaps, grommets, etc., but I don't own it, . . . cannot comment on it.
May God bless,
Dwight
www.dwightsgunleather.com
#12 TomG
TomG
    Leatherworker
  • PipPipPip
  • 617 posts
  • Gender:Male
  • Leatherwork Specialty:Belts, and Bracelets, Dog collars and leashes
  • Interested in learning about:Anything for improving my skills
Posted 14 April 2012 - 11:28 PM
May God bless,
Dwight
BUMP
I bought this snap setter last week. The handle bent before the post was split/curled. Took it back and and exchanged it., Same thing.
Went to West Marine and bought a heavy duty one for $34 with 18 heavy duty snap sets and it works perfectly.
Don't waste your time or money at HL.
Tom
#13 Sylvia
Sylvia
  • PipPipPipPip
  • 1,855 posts
  • Gender:Not Telling
Posted 15 April 2012 - 12:23 AM
BUMP
Does West Marine have a website? If so would you please post a link for us?
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
#14 TomG
TomG
    Leatherworker
  • PipPipPip
  • 617 posts
  • Gender:Male
Posted 15 April 2012 - 11:04 AM
Here you go. Be sure to copy and paste the entire URL into your browser. I noticed that it's wrapped onto 2 lines here.
http://www.westmarin...&classNum=50699
Tom
#15 Sylvia
Sylvia
  • PipPipPipPip
  • 1,855 posts
Posted 15 April 2012 - 11:54 AM
Tom
Thanks Tom! The link ended up clickable. Funny I notice that several people reviewed this product as worthless and said that it bent after a few uses. I wonder if they are coming from a couple different factories....
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
