Leatherworker.net: Rawhide tutorial - Leatherworker.net
  • (2 Pages)
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
Rawhide tutorial Making Rawhide
#1 User is offline   rgerbitz Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Leatherwork Specialty: Rawhide braiding
  • Interested in learning about:western tack, chaps, chinks, etc...
Posted 29 May 2008 - 09:44 PM
Here's how I did it. This is about my 9th or 10th time I've done this and I still have quite a bit of room for improvement. Hope this helps anyone thinking they may want to try this. And if there are any thoughts on what I might have done diffferent or better I would be happy to hear them.
First I purchased the hide from the local meat locker for $40 and was able to start working with it within 3 hours of the last heart beat.
All of the excess fat and meat was removed first
Attached File  Taking_fat_offf.JPG (256.84K)
It is a great way to get some peace and quite, cause nobody wants to be around for that.
Next, drop the whole works in a barrel of water with a coffee can of barn lime mixed in. I have found that starting with warm water seems to speed up the process alot. (Thank you KAW for that)
Attached File  hide_in_lime.JPG (206.93K)
After 3 days in the lime the hair was ready to slip or push off, I layed a 2x6 between 2 barrels and pulled the hide over that.Attached File  hide_on_barrels.JPG (240.39K)
It's best to do this in a shady spot, so as not to get the hide sunburned.
If everything has gone according to plan the hair should come off fairly easy, it did this time but I have had to wait close to 2 weeks before the hair would slip. I think it was because it was in the fall and it was to cold.
Attached File  scraping_hair.JPG (267.57K)
After I get the hair all scrapped off I rinse the hide with the garden hose trying to get as much of the lime and hair off as possible.
Then it's back into the barrel for 24 hours with a gallon of vinagar and enough water to cover the whole hide.
(continued on nex thread)
#2 User is offline   rgerbitz Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 29 May 2008 - 10:12 PM
After pulling the hide from the vinegar and water I rinsed it again, but you will see later that I didn't get a good job done of that.
Then it was layed out and strethed on a frame made of some old fence posts.
Attached File  hide_streched_out.JPG (230.76K)
The hair left on the hide is there because I was running short on time and had to quit on it.
After the hide had dried completely I was able to remove the remaining hair with a knife held perpendicular to the surface the hide and scrapped it off. I scrapped all the hair off the first hide this way, I don't recommend it, it really sucks.
Attached File  dry_scraping.JPG (243.45K)
Attached File  all_finished.JPG (249.59K)
After finishing up on the hair I took a home made compass that can mark out up to a 3 foot circle, and layed out the cirlces I could cut out trying my best to avoid any weak spots in the hide that might make for some junk string later. I then used a pair of tin snips to cut those circles out while the hide was still dry.
Attached File  circles_out.JPG (232.79K)
I will later soak those circles in water for an hour or so then temper for the better part of a day then cut a skive into string to be braided with. Maybe I can make a tutorial of that someday.
You can kinda of see in the last picture some chalky areas on the hide, I think I either didn't leave it in the vinagar long enough or I didn't do a good job of rinsing it out that last time.
Please feel free to question or critique anything I have done, like I said earlier I know I have some room for improvement.
If there is something that isn't clear please let me know, there are a few more pictures that might help.
Have a good one
Rob
#3 User is offline   Timothy Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:Horses
  • Leatherwork Specialty:Begining Rawhide Braiding
  • Interested in learning about:Advanced braiding, Tooling
  • How did you find leatherworker.net?:Internet search
Posted 30 May 2008 - 01:48 AM
Thank you Rob,
I've been wanting to try this, and the pictures really help.
I do have a couple of questions.
About what size is your frame?
Just out of curiosity, was the big circle the butt? I haven't worked with many large pieces so I can' tell.
Timothy
#4 User is offline   rgerbitz Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 30 May 2008 - 06:28 AM
Hello Timothy,
Glad you like it. The frame is 7 1/2 foot square and it could be a bit bigger, maybe 8 x 8. But this one works just good enough that I can't bring myself to change.
The big cirlce was from the neck, usually I can't cut across the whole neck like that cause of bug damage to the top line but this one was in really good shape.
Hope this helps
Rob
#5 User is offline   carr52 Icon
  • Leatherworker
  • PipPipPip
  • Group: Contributing Member
  • Gender:Male
  • Interests:I just like to make things. Use to do a little leather work when I was younger and thought I'd give it another try. I had forgotten how much fun it really is.
  • Leatherwork Specialty:none
  • Interested in learning about:all of it
  • How did you find leatherworker.net?:at tandys
Posted 30 May 2008 - 06:43 AM
Great tutorial. Thank you. I wont be happy till I try it now.
Thanks again, Tom
#6 User is offline   Timothy Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:Horses
Posted 01 June 2008 - 03:29 AM
Thank you Rob.
I'm going to build one and try to find a hide locally.
Timothy
#7 User is offline   pavilionpony Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Female
  • Interests:Horses, hunting, fishing, leather work, drawing, painting
  • Leatherwork Specialty:I love all areas of leather
  • Interested in learning about:all I can :)
  • How did you find leatherworker.net?:google search
Posted 24 June 2008 - 11:38 PM
Oh wow Rob. Thank you for posting. I wish I knew this before we butchered (and buried the hides of- the shame of it!!!) two cows last month. I'm always late and never win on a lottery ticket either! Darn. I will definatley hang on to this info! :)
#8 User is offline   rawhider Icon
  • Member
  • PipPip
  • Group: Members
  • Leatherwork Specialty:rawhide braiding
  • Interested in learning about:perfecting my work as a braider
Posted 06 September 2008 - 09:43 AM
Great post! Thats how i've done most of my hides, but I love seeing how other folks do it. I always learn something new.
Question: What is the purpose of soaking the hide in a water/vinegar mix after you've slicked the hair? :popcorn:
#9 User is offline   rgerbitz Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 16 September 2008 - 06:17 AM
The vinegar helps to nuetrilize the effects of the lime and dissolve what may be remaining off. I have had hides that I did not leave in the vinegar long enough turn out with a kind of chalky film on them in places.
Rob
#10 User is offline   Hennessy Icon
  • Member
  • PipPip
  • Gender:Male
  • Interests:middletons roustabout [hardback]flying ultralites,makin stuff in leather wotever ,trying to figure out how to help hurting horses.open minded horse owners and saddlemakers thru cordial discussion.
  • Leatherwork Specialty:rodeo gear and saddles and custom leatherwork
  • Interested in learning about:wotever
  • How did you find leatherworker.net?:read of it in a magazine
Posted 28 November 2008 - 07:09 PM
Rob
rob an old tree maker from n z told me he slipped hair by laying hide over a rapid in a fast running creek.lay a few rocks on it as an anchor,move rocks around every day or so hide will enlarge n hair will slip.whats left is rawhide ,make sure you drink from creek above rapid adios peter john
#11 User is offline   RockingMleather Icon
  • New Member
  • Pip
  • Group: Members
  • Leatherwork Specialty:Tack
  • Interested in learning about:Saddle Repair
  • How did you find leatherworker.net?:search
Posted 29 July 2009 - 10:42 PM
This thread was very helpful! Now where can i find out how to start cutting strands and braiding etc. Im sure i can figure out how to do different braiding patterns and how to make certain tack on this website but i am more concerned on learning the process after the tanning, like starting to cut to make thread and everything else i need to know. Thanks for any help.
#12 User is offline   Hilly Icon
  • Leatherworker.net Regular
  • PipPipPipPip
  • Gender:Female
  • Interests:Leatherwork, photography, bird dogs, nature, hunting, camping, plinking with a pistol.
  • Leatherwork Specialty:None yet, but wanna try it all.
  • Interested in learning about:All types of leatherwork and the people that hang here.
Posted 30 July 2009 - 08:45 AM
One of our members "Whitebuff" makes a nice string maker for thinner leathers, such as calf. I bought one when I was a total newbie to braiding. I learned to use the string maker in about 20 minutes. Of course, I only make small items for now - bracelets, key fobs, scarf slides and such, and I use kangaroo hide, but the method is pretty much the same for anything braided.
I still want to take a stab at braiding with calf rawhide, but I just can't find the time right now. :bawling:
#13 User is offline   TexasLady Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Female
  • Leatherwork Specialty:Just getting started in leather.
  • Interested in learning about:Stranding, braiding.
  • How did you find leatherworker.net?:I Googled 'Australian Strander'and found the leatherworker.net.
Posted 01 August 2009 - 05:51 PM
[quote name='RockingMleather' date='Jul 29 2009, 10:42 PM' post='118153']
I agree with 'Rocking'. I'm searching the forum today because I've purchased an entire small rawhide and I need to learn about cutting it into strands. I own an Australian Strander (from Tandy Leather). It doesn't look too difficult to figure out, but I haven't used it yet. It would be great if rgerbitz would show up again with the next steps. Somebody please come tell us how to make strands out of rawhide. (Something about needing a certain moisture content?) And if you know where there's a good rawhide whipmaking tutorial, better yet. - TexasLady
This post has been edited by TexasLady: 01 August 2009 - 05:53 PM
#14 User is offline   JSaddlery Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Leatherwork Specialty:Saddle and tack repair
  • Interested in learning about:rawhide braiding
Posted 17 September 2009 - 08:46 PM
First time at doing this, do you just use food grade vinegar or some other kind
#15 User is offline   D.A. Kabatoff Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Leatherwork Specialty:Saddlemaking
Posted 17 September 2009 - 11:46 PM
Rob,
thanks for that tutorial! I've heard different treemakers talk about making their rawhide before but I now have a new appreciation for what they go through!
Darc
Share this topic:
  • (2 Pages)
  • 1
  • 2
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
