Consew 226R-1 Initial Setup/small Problems Help
  • Please log in to reply
13 replies to this topic
#1 hobageeba
hobageeba
    Member
  • PipPip
  • 25 posts
  • Gender:Male
Posted 15 February 2012 - 12:39 PM
Hey Guys,
I'm a new owner of a Consew 226R-1 and I need some help getting it all setup and sussing some problems out. I'm completely new to sewing machines (well, except for really cheap home machines) and am not the most mechanically inclined so please be patient with me. I spoke on the phone with Bob from Toledo Sewing Machines a bit today, who I bought a servo motor off, but I didn't want to bug him too much so I'm hoping some of you out there could give me a hand. Any help or suggestions whatsoever would be hugely appreciated. Thanks!
I have a million and one questions but I'm going to try and keep this concise and post a couple questions/problems at a time.
One of the most noticeable problems I'm having is that after switching to 138 thread, the top thread won't manually feed when I try to pull on the thread without me giving it some slack by hand first. By that, I mean, I have to tug on the thread right after the first post it threads through to give it slack, then pull from where it exits the needle. There doesn't seem to be any excessive tension anywhere, it just seems to be a cumulative effect. This leads me to wonder if I'm threading it wrong, which by reading the manual and looking at all the comparative pictures and youtube videos I can find, it seems I'm doing it right.
One thing Bob mentioned is that the tension discs may not be disengaging, which is actually true, but even with the tension discs screwed all the way loose so there's no tension on the thread, I still can't pull the thread from the needle.
Obviously, another concern is fixing the tension discs. I do see that there's a metal plate on the back that pushes against a spring to disengage the threads, but I don't see any mechanism that would push the plate to disengage. Hmmm...
I'll attach some pictures of the whole setup as well as details of how I'm threading it. I am very likely screwing something up somewhere so let me know if you see something fishy. Thank you!
The whole setup:
Attached File  image-5.jpeg   83.74KB   205 downloads
Threading detail:
Attached File  image-3.jpeg   74.01KB   237 downloads
Attached File  image-4.jpeg   77.34KB   232 downloads
Attached File  image.jpeg   82.13KB   247 downloads
Attached File  image-2.jpeg   79.11KB   235 downloads
Attached File  image-1.jpeg   72.94KB   177 downloads
#2 Wizcrafts
Wizcrafts
    Leatherworker.net Regular
  • PipPipPipPip
  • 3,179 posts
  • Gender:Male
  • Interests:Leathercraft, contract sewing, Country-Western music, computer consulting and PC and website security and freelance Webmaster for hire.
  • Leatherwork Specialty:Belts, custom holsters, knife sheaths, guitar straps, rifle slings, custom vests, pouches/cases, wallets/purses, weight lifting belts, contract sewing
  • How did you find leatherworker.net?:Google search
Posted 15 February 2012 - 02:31 PM
Just go through one hole in the top post. And fix that thread cup on the stand. They should both be horizontal with spools in place.
I wrap my thread around the three holes in the guide above the tension disks. You seem to have daisy wired it in and out.
If the lift mechanism fails to release the tension disks, unscrew the nut until it barely applies pressure. Does the lifter now separate the disks?
  • Yes > you had too much top and bottom tension. Loosen the bobbin spring so you can keep the top spring backed off some.
  • No > loosen the set screw on the right side of the body for the top tension assembly. Push the tensioner assembly inward and tighten the set screw.
If reseating the tensioner fails to cause the disks to separate, the problem may be a worn, or misaligned push rod actuator. Remove the tensioner assembly completely and see if the thin rod in the center protrudes at least 1/16" beyond the back. If not, see if the retainer plate can be forced inward in the middle area. You must have some rod protruding out the back in order to have the disks separate.
If the rod stitcks out enough but fails to separate the disks, follow the path backwards to the lift lever. See if any parts or bent out of shape or loose.
You can replace any worn or bent parts, or the tensioner assembly, to restore normal operation of the lifter and tension release functions. The parts are definitely under one thousand dollars.
Posted IMHO, by Wiz
Cowboy CB4500, Singer 139w109, Singer 29k172, Singer 29k71, Singer 31-15, Singer 42-5, Fortuna power skiver, Consew portable blindstitch machine, Pfaff 4 thread, 2 needle serger, and various old iron body Singer straight stitch portable machines (including a 1902 Model 27).
#3 CowboyBob
CowboyBob
    Sewing Machine Dealer
  • PipPipPipPip
  • 1,518 posts
  • Gender:Male
  • Interests:We sell New & Used
    Leather Sewing Machines
    Parts,Needles &Thread
  • Leatherwork Specialty:Can help w/sewing machine questions & supplies
  • Interested in learning about:People needing help with machines
Posted 15 February 2012 - 03:27 PM
Here's a pic of the tension release bracket & the rod that pushes on the back of the tension unit,you need to see if this rod is moving foward when you lift the foot all the way up if so this bracket isn't broke,
the bracket right behind the tension is adjusted by bending it alittle towards the back of the machine.
You can shine a light into the side of your machine & look at this part & see if it's broken or not.
Bob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#4 hobageeba
hobageeba
    Member
  • PipPip
  • 25 posts
  • Gender:Male
Posted 15 February 2012 - 07:56 PM
Thanks a ton guys! Gonna go through this one by one...
Just tried that and it seems better. Still pretty hard to pull though...is that just the nature of the thicker thread? The cup stands seemed wrong to me...ha. Will definitely fix it.
I've seen pics of it both ways. The manual reads "Pass thread in weaving fashion through the three holes in guide.." I took that to mean up and down. Am currently trying it your way.
Upon further inspection, it was moving it. Just a small amount so I didn't notice before. It could probably push it out a little further.
I think I may need to do a little of both of this as it is pushing, but not enough. As for loosening the bobbin tension...I can't figure out for the life of me how to do this from what the manual describes. Is one of these the screw/s you're supposed to adjust?
Attached File  image-3.jpeg   66.89KB   134 downloads
If so, mine are near impossible to get to and adjust. Does it matter which one?
Is this what you refer to as the bobbing spring?
Attached File  image.jpeg   62.74KB   138 downloads
And while we're at it, do you seat the bobbin so it spins counterclockwise like this:
Attached File  image-1.jpeg   70.24KB   119 downloads
or clockwise like this:
Attached File  image-2.jpeg   76.95KB   116 downloads
Is this the set screw you're referring to?
Attached File  image-4.jpeg   67.21KB   116 downloads
Thanks so much!
Thanks for the reply Bob. The picture didn't make it on your post?....
Bob
#5 CowboyBob
CowboyBob
  • PipPipPipPip
  • 1,518 posts
  • Gender:Male
Posted 16 February 2012 - 09:04 AM
Ok,I found out the file is to large to upload here, so if you want to PM me your email address I'll email to you.
Thanks,Bob
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#6 hobageeba
hobageeba
    Member
  • PipPip
  • 25 posts
  • Gender:Male
Posted 16 February 2012 - 07:18 PM
Thanks Bob, PM sent. Can anyone tell me which way the bobbin's supposed to go in?
#7 busted
busted
    Member
  • PipPip
  • 313 posts
  • Gender:Male
  • Leatherwork Specialty:tack, belts, saddlebags, western holsters and belts
  • Interested in learning about:most anything
  • How did you find leatherworker.net?:a friend
Posted 16 February 2012 - 10:22 PM
Hey Guys,
The whole setup:
Threading detail:
The thread is not between the discs in the fifth photo from the top. It looks to be behind the rear disc instead of between both disc.
Edited by busted, 16 February 2012 - 10:26 PM.
#8 Gregg From Keystone Sewing
    Leatherworker
  • PipPipPip
  • 502 posts
  • Gender:Male
  • Interests:Leather Sewing Machines and related equipment
  • Leatherwork Specialty:Sewing
  • Interested in learning about:Leather work and machines
  • How did you find leatherworker.net?:Intenet seach
Posted 17 February 2012 - 12:01 PM
Posted Image
Hope this image helps!
First thing I noticed is that 226R is SUPER clean. I haven't seen on like that in a long time.
I would do what Bob is recommending to do here, and Wiz is on the right path as well;
Bend index #9 tension release lever, this is behind the tension plate index #8. I would do this on the machine, wiht needle nose pliers. To set, adjust this, I would lower the feet down, and have both feet equal flat, or touching the feeder and needle plate at the same time. Then...Bend that tab so that there is a trifle of noticeable play between the plate index #9, and the not visible tension release rod. This is the rod that pushes the tension release lever whenever we lift the feet by hand lever or knee lifter. This way, we can remove the work from the machine easily, when the take up lever is at it's highest point.
Hope this is clear and helps!
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
#9 hobageeba
hobageeba
    Member
  • PipPip
  • 25 posts
  • Gender:Male
Posted 18 February 2012 - 03:05 AM
Thank you so much! I'll definitely try that. I seriously appreciate your guys' time and help. So moving on with some more complete newbie questions:
Still not sure which is the correct way for the bobbin to go in - Should it spin clockwise or counter-clockwise?
When I oil, do I just give a few drops each time? Should I be hitting any other spots other than the spots market with red and the felt pad?
On the topic of oiling - there's a big hole on the right side of the machine (the only hole marked with red on the right side) that's sort of a chasm into the machine...not sure what I'm supposed to be hitting with oil there.
Thanks!
Posted Image
#10 CowboyBob
CowboyBob
  • PipPipPipPip
  • 1,518 posts
  • Gender:Male
Posted 18 February 2012 - 08:07 AM
The bobbin goes in so it turns counterclockwise.
Oil anything w/hole & open the cover over the needlebar & oil all the pivoting joints in there too.
Also oil the outer part of the bobbincase everytime you go to use the machine & or everytime you replace the bobbin.
Open the top cover just to the left of the handwheel & you'll be able to see the raise part w/o oil hole in it .
On these oiling diagrams,the oil spots are marked with arrows.
Bob
Edited by sewmun, 18 February 2012 - 08:09 AM.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#11 hobageeba
hobageeba
    Member
  • PipPip
  • 25 posts
  • Gender:Male
Posted 18 February 2012 - 11:07 AM
Holy smokes, that's a whole lot more than just the red spots!! I guess hitting all these spots becomes second nature after you've done it for a while.
Thanks for addressing the bobbin issue...I definitely had it going the wrong way!
Bob
#12 ezurcc
ezurcc
    New Member
  • Pip
  • 5 posts
Posted 05 November 2013 - 11:30 AM
Hello everyone,
I'm new here and was needing help adjusting the bobbin tension on my Consew 226R-2 also. The manual I have must be the same one hobageeba has. It instructs you to turn the screw near the center of the spring... I have removed the bobbin and do not see anything that resembles a spring. Can anyone give me a "heads up" on where this spring is? I realize this thread is over a year old, but any help would be appreciated. Thanks.
#13 CowboyBob
CowboyBob
  • PipPipPipPip
  • 1,518 posts
  • Gender:Male
Posted 05 November 2013 - 12:41 PM
Here's some info from a Singer manual,use screw marked "AC" for tension adjustment.
Edited by CowboyBob, 05 November 2013 - 12:43 PM.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#14 ezurcc
ezurcc
    New Member
  • Pip
  • 5 posts
Posted 05 November 2013 - 04:28 PM
Thank you, sir! How much for a copy of that manual?
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
