Juki 441 Clone Versus Adler 205-370
  • Please log in to reply
34 replies to this topic
#1 Steven Kelley
Steven Kelley
    Member
  • PipPip
  • 168 posts
Posted 23 February 2012 - 08:31 AM
I've had a Juki 441 clone for about 8 months. Late last year, I made the decision to purchase a 2nd machine to speed things up a bit (aka - get my wife to help me stitch things!). So I was going to buy another Cowboy 4500. I love the Cowboy 4500 by the way. It's been absolutely fantastic. The stitch quality is great. It's a very well built machine, and Bob's customer service can't be beat. I also had a itch for an Adler 205, but didn't want to pay twice the price for the Adler when the Cowboy would make the same quality of stitch.
So one night I'm searching Craigslist and run upon a local guy selling a used Adler 205-370. To make a long story short, he inherited it from his father, who was a saddle maker and purchased the machine very shortly before passing away. It had been used a total of 2 times. It looked brand new. I bought it for roughly 1/2 the price of a new one. Obviously, I couldn't pass that up. So I've been using it for a few weeks now trying to get it all dialed in, which I now have.
So after using both side by side, this is my comparison for any of you trying to decide between a 441 clone machine or an authentic Adler 205.
The only issue I've had with the Cowboy has been with the servo motor. It starting acting up a bit and Bob sent out a new motor. The Adler, not being setup for holsters, took some tweaking.
The Adler is a more "polished" machine. You can tell the attention to detail of all the parts is a little better. The machining is nicer, paint is nicer, knobs are nicer, etc. It's 2x the price new, so it should be, right? But when it actually comes down to stitching, I can't tell a difference. They stitch virtually the same.
One neat feature of the Adler is that when you press the pedal to lift the presser foot, it relieves tension on the top thread so you can easily pull your piece out. Not a big deal, but neat.
I like the harness feet on the Cowboy better. They are a little smaller and smoother, so it's easier to see exactly where your stitch is going, and a little easier to go around corners with.
Tension control is the same.
Threading the machines is totally different, but very easy on both.
The area in the machine where the stitching happens is more "open" in the Cowboy, which I like. That makes it easier to see everything.
The stand that comes with the Adler (from Weaver's) is a little heavier duty, but doesn't lift high enough to stand and sew. The Cowboy stand is plenty heavy and has a much broader range of height adjustment, from sitting to standing.
The bobbin winder on the Cowboy is a part of the machine, and it works very well. The bobbin winder on the Adler is an separate piece that is mounted to the table. It has a wheel that contacts the drive belt when engaged. Both work well, but the winder on the Cowboy gives me a more consistently full bobbin than the Adler winder. I cannot adjust the Adler winder to fill the bobbin more full, so I need to modify it a bit.
One small nit picky item is the door covering the bobbin/shuttle area. I hate the hinged door on the Adler. There is a spring wire that holds the door closed. You have to use a screwdriver to pry the spring back and open the door. I hate it. I love the cover on the Cowboy. Just turn it one way and it pops right off. Turn it back the other way and it's locked in place.
The Cowboy will sew thicker leather than the Adler. I don't know the exact thicknesses off hand, but the presser foot lifts quite a bit higher with the Cowboy, if that's a concern for anyone. I don't sew anything near the max thickness for either one, so it's not a big deal for me.
They are both extremely well built and very heavy duty. I can't imagine either one being "under built" for anything you want to run through them. Obviously, the Cowboy being a Chinese built clone, isn't going to be as nicely fit and finished as an authentic Juki or an Adler, but it is very nicely built and finished nonetheless. Having both and using both side by side, now I am very confident in saying that unless you find a screaming deal on a more expensive machine (Juki or Adler), don't waste your money. The Cowboy will stitch just as well, it's built like a tank, and you'll get customer service to last a lifetime. I'm sure Cobra, Techsew, etc. are probably equally as good. I've only used the Cowboy so that's all I can speak to. Bob is great to work with. Steve has lots of great reviews, as does Ronnie from Techsew. I have had to deal with Weaver's for a few small things for the Adler, and they have been very helpful as well.
Now back to work.
#2 busted
busted
    Member
  • PipPip
  • 313 posts
  • Gender:Male
  • Leatherwork Specialty:tack, belts, saddlebags, western holsters and belts
  • Interested in learning about:most anything
  • How did you find leatherworker.net?:a friend
Posted 23 February 2012 - 10:00 AM
If your Adler isn't over 10 years old it is made in China.
Now back to work.
#3 Steven Kelley
Steven Kelley
    Member
  • PipPip
  • 168 posts
Posted 23 February 2012 - 11:29 AM
It's less than 10 years old. Plate says made in Czech Republic, but a large percentage of it could be from China.
#4 CowboyBob
CowboyBob
    Sewing Machine Dealer
  • PipPipPipPip
  • 1,516 posts
  • Gender:Male
  • Interests:We sell New & Used
    Leather Sewing Machines
    Parts,Needles &Thread
  • Leatherwork Specialty:Can help w/sewing machine questions & supplies
  • Interested in learning about:People needing help with machines
Posted 23 February 2012 - 12:02 PM
Steve,
Sounds like a good deal.Years ago when we sold Adlers we had a big problem with the Amish,when they sewed the heavy work tugs the needle would pull out.So what they did was grind a flat spot on the shank to hold it in.That screw just is to small to get it tight enough to hold.I've heard the newer machines have 2-screws on them,does yours?
That's about the only fault on them but we always felt bad when we told people to put a flat spot on the needle to hold it in(Were ta;lking a $5,000.00 machine).We used to sell alot of those needle set screws too as they stripped out real easy.I could never understand why they couldn't put a larger screw on it like the 441's.
We also would drill a 3/8" in the plastic @ the top of the takeup lever so you can see when the takeup lever is all the way up.
Bob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#5 oldtimer
oldtimer
    Leatherworker
  • PipPipPip
  • 780 posts
  • Gender:Male
  • Leatherwork Specialty:saddles and tack
  • Interested in learning about:all kind of leatherwork
Posted 23 February 2012 - 12:13 PM
It's less than 10 years old. Plate says made in , but a large percentage of it could be from China.
No Adler 205 is made in China. They are all made in the Czech Republic !
/ knut
"The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
#6 Steven Kelley
Steven Kelley
    Member
  • PipPip
  • 168 posts
Posted 23 February 2012 - 12:17 PM
Steve,
Bob
Bob,
Mine only has one screw holding the needle. And you are right about the take up lever. Being able to see it would be nice, but since the tension is released when the presser foot is raised, at least you don't need access to it. I'm glad to have it, and also very happy that the quality and performance of the Cowboy is on par with the Adler. Its not that the Adler is lower quality than I expected, but that the Cowboy is exceptional, and for half the price new.
#7 amuckart
amuckart
    Leatherworker
  • PipPipPip
  • 545 posts
  • Gender:Male
  • Interests:Medieval reenactment
    footwear, purses and casework
    medieval and renaissance shoes
    old sewing machines
  • Leatherwork Specialty:Reproduction medieval shoes
  • Interested in learning about:Sewing machine restoration/operation
  • How did you find leatherworker.net?:Google
Posted 23 February 2012 - 02:35 PM
The Cowboy should have this too. My Hightex 7441AE, which is the same machine from the same factory, has a part connected to the foot lift mechanism that spreads the top tension plates.
Have a look at this post on my thread about the machine about midway through the post there are pictures of the mechanism. it doesn't disengage the lower 'wrap-around' tension mechanism though.
-- Al.
Medieval Stuff: http://wherearetheelves.net
Non-Medieval, including my machines: http://alasdair.muckart.net
#8 awharness
awharness
    Member
  • PipPip
  • 300 posts
  • Gender:Male
  • Leatherwork Specialty:Horse harness
Posted 23 February 2012 - 03:27 PM
I would agree! I had an adler 204 flat bed and Ive had chinese 441 copies, the adler was a lot better built, but when push came to shove that Chinese machine just works! and works and works! and the 441 should release the top tensioniers when you kick down the presser foot lift...
-Andrew
#9 CowboyBob
CowboyBob
  • PipPipPipPip
  • 1,516 posts
  • Gender:Male
Posted 23 February 2012 - 03:56 PM
Yes,I forgot to mention he's correct the Cowboy has a tension release too.It's right underneath the first tension umit & is activated when you pickup the foot,it's a black lever.
When you take off the end cover plate to oil the parts inside you need to make sure you line the pin up when you put in back on.
Bob
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#10 busted
busted
    Member
  • PipPip
  • 313 posts
  • Gender:Male
Posted 23 February 2012 - 05:38 PM
/ knut
A thousand apologies to the fine Czeck Republic manufacturing capabilities.
Edited by busted, 23 February 2012 - 05:38 PM.
#11 Steven Kelley
Steven Kelley
    Member
  • PipPip
  • 168 posts
Posted 24 February 2012 - 07:39 AM
Bob
Yes, mine does have that and it is working properly. It just does not release enough tension so the piece can be easily pulled out of the machine, without pulling thread by hand from the take up lever. It does release some tension, but not enough. It's really not a big deal at all. Maybe it's the way I have the tensions adjusted on the machine. The Adler releases quite a bit more of the tension, so that you can just pull the piece out.
I have white thread in one and black in the other. After using the Adler a few days exclusively, I needed to use the Cowboy yesterday. Overall, I actually like stitching on the Cowboy more than the Adler.
#12 CowboyBob
CowboyBob
  • PipPipPipPip
  • 1,516 posts
  • Gender:Male
Posted 24 February 2012 - 10:22 AM
You know that's a great idea that everyone should do..have a machine for each color.
Sounds like you still need another machine for the brown??
Bob
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#13 Steven Kelley
Steven Kelley
    Member
  • PipPip
  • 168 posts
Posted 24 February 2012 - 12:46 PM
Bob
Bob,
When I get ready for a third machine, you'll be getting an order for another Cowboy. No doubt about that.
#14 Wizcrafts
Wizcrafts
    Leatherworker.net Regular
  • PipPipPipPip
  • 3,165 posts
  • Gender:Male
  • Interests:Leathercraft, contract sewing, Country-Western music, computer consulting and PC and website security and freelance Webmaster for hire.
  • Leatherwork Specialty:Belts, custom holsters, knife sheaths, guitar straps, rifle slings, custom vests, pouches/cases, wallets/purses, weight lifting belts, contract sewing
  • How did you find leatherworker.net?:Google search
Posted 24 February 2012 - 02:15 PM
Steven;
I find that using a single wrap around the bottom tension disk (not really a tension disk per say) allows the thread to feed much easier than a double wrap. I set the required tensions between the bobbin spring and first tension disk set. When I release the work with the foot lifter, I can pull the threads out very easily. Double wrapping the bottom disk makes it harder to pull the thread out.
Furthermore, if you go through two holes in the top post, it is harder to pull the thread out.
Black thread is springier than white thread and needs more TLC in the feed path.
Posted IMHO, by Wiz
Cowboy CB4500, Singer 139w109, Singer 29k172, Singer 29k71, Singer 31-15, Singer 42-5, Fortuna power skiver, Consew portable blindstitch machine, Pfaff 4 thread, 2 needle serger, and various old iron body Singer straight stitch portable machines (including a 1902 Model 27).
#15 wnkleather
wnkleather
    Member
  • PipPip
  • 17 posts
Posted 03 April 2012 - 05:57 PM
Just wondering if anyone has a 20 year old Chinese machine that sews like my 30 year old Adler 205?
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
