How Do I Stop Leather From Shedding?
  • Please log in to reply
3 replies to this topic
#1 jokun
jokun
    New Member
  • Pip
  • 1 posts
  • Gender:Female
  • Leatherwork Specialty:bags
  • Interested in learning about:techniques and better ways to do things
Posted 20 April 2012 - 03:31 PM
Hello,
I'm new here! I started leather working about 4 years ago - I make handbags. For the most part I use 3-5oz leather - mostly upholstery hides, and have just started using some thicker oil tanned leathers and some vegetable tanned leathers. Until recently, I have always lined my bags, but lately I have been wanting to make some that are unlined. What is the best way to stop the flesh/suede side of the leather from shedding? I have been looking online for a long time for recommendations for this, but I never really get any good answers. Is there some kind of finish I can apply to flatten the fibers? I've tried to skive some pieces before but that doesn't really work well for softer upholstery leathers. I've wondered if a sander would help, but I'm not sure. Is there a different type of leather I should be using for these types of projects?
On the same line, what is the best way to finish edges for non-vegetable tanned leathers to keep them from shedding? I've seen some bags in stores that seem to have a raw seam that has been coated in a wax or something similar - yet I can't find anything about it anywhere! Any help would be appreciated! This seems like such a simple question, so I feel like there must be something I'm missing.
Thanks,
Julia
#2 Sylvia
Sylvia
    Leatherworker.net Regular
  • PipPipPipPip
  • 1,855 posts
  • Gender:Not Telling
  • How did you find leatherworker.net?:Google
Posted 20 April 2012 - 04:07 PM
Hello,
Thanks,
Julia
Hi Julia:
On veg tanned, I've had good luck with sanding with 100 grit then 220 grit sand paper (by hand and using a finish sander) I do suggest that you do this well away from your normal working area because the sander especially will fling leather dust all over. Either way the result is a fine texture similar to suede. here it comes... the big "BUT" The quality of your leather is going to be a huge factor. If you choose to go with cheaper leather the backs can have large chunks of loose fibers come up leaving a line or divot... and you have to skive or sand past those. Then I start with water and saddle soap work that in by hand until it feels slick... and let that dry. Then I go over that with Gum Tragacanth which smooths it down even more. Finally I seal it with one of the "shenes" or Resolene type product.
As to your question on the thin leather edges. I've seen this on youtube but have not found the a product either. It seems that it's a sort of colored wax that is applied and gone over with a hot iron (like a soldering iron but with a flat fan-like blade) the result is a smooth sealed edge. ( suppose one could try dying the edge, rubbing it with beeswax then holding a hot iron to it... but do that on a practice piece before you try it on any finished good)
Good luck.
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
#3 js5972
js5972
    Member
  • PipPip
  • 126 posts
  • Gender:Male
  • Interests:Bass fishing, leatherwork, travel
  • Leatherwork Specialty:tooled cases, belts, holsters
  • Interested in learning about:working with dyes & stains
  • How did you find leatherworker.net?:read about it in another forum
Posted 01 May 2012 - 08:04 PM
On thinner leather, I burnish by rubbing a damp bar of saddle soap directly on the leather. Sounds a little goofy, but it works. The square edge of the soap works as a rub stick.
John Schmitz
New to Oklahoma City
via Baja Arizona
#4 jimmy eng
jimmy eng
    Member
  • PipPip
  • 81 posts
  • Gender:Male
  • Interests:Clothing design, Dance, Theater, Film, Photography
  • Interested in learning about:hand stitching, molding leather, finishes, history
Posted 03 May 2012 - 10:14 PM
In regards to the raw seam, are you talking about Louis Vuitton handbag edges? They use a kind of shellac that's a shade specifically made for them. It's one way to tell a fake if it's the wrong colour.
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
