Covering handles for crops and other items
  • Please log in to reply
105 replies to this topic
#1 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
  • Leatherwork Specialty:BDSM items (floggers, collars, restraints, etc)
  • Interested in learning about:armor, holsters, molding, clothing, pretty much anything leather related
  • How did you find leatherworker.net?:did a search for
Posted 18 January 2008 - 05:27 AM
TOOL LIST
Template
24" straight edge
Small hammer
Kite string (yes. Kite string)
Scratch awl
Pneumatic stapler (with 18 ga. x 1" staples) or you can use 1 1/4" x 16 nails
65mm rolling cutter
Leather shears
Exacto knife
6" metal molded ruler
45 degree corner line placer for 2x4s
Small curved forceps
Needle nose pliers
Pencil, pen, silver ink pen
13" straight edge
Lacing needle (not pictured)
Small fib (not pictured)
Something to cut the dowel (I use a miter saw) (not pictured)
Attached File  how_to_1.jpg   892.22KB   1583 downloads
Pick what leather you want to use for your tails, your handle braid, your Turks heads, the handle base (1" OAK dowel), leather glue (not pictured), gel super glue (not pictured), " x 19 nails, and some tacks.
Attached File  how_to_2.jpg   820.99KB   1364 downloads
Edited by Johanna, 25 January 2008 - 06:40 PM.
frissenfrassenmussafrussen...
#2 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 05:33 AM
Pick your handle braid style.
Attached File  how_to_3.jpg   152.36KB   1784 downloads
Cut your handle braid leather ( " x 13" or 14" for most handle braids)
Attached File  how_to_4.jpg   1006.48KB   1931 downloads
Take the 2x4 corner angle tool and use it to draw a line on the end of the dowel after cutting it to the length you want. I use 7". Turn the dowel 90 degrees and do the same thing again so you have an "X".
Attached File  how_to_5.jpg   280.92KB   1943 downloads
Take the pencil, set it on top of one of the straight edges, place the end of the dowel you made the "X" mark on against the edge and the pencil and spin it so you have a line all the way around it about 1/8" from the end.
Attached File  how_to_6.jpg   712.11KB   1333 downloads
Line a tack up with the lines and make a hole with it at all 4 points.
Attached File  how_to_7.jpg   1.06MB   783 downloads
Edited by Drac, 18 January 2008 - 06:09 AM.
#3 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 05:38 AM
Now take a tack and put a hole at one end of each handle braid strip.
Attached File  how_to_8.jpg   300.18KB   671 downloads
Now put a " x 19 nail through 2 strips according to what pattern you picked.
Attached File  how_to_9.jpg   215.7KB   806 downloads
Use the needle nose pliers to hold the nail in the starter hole you made in the dowel and hammer it in with the small hammer. Make sure you don't set the nail completely yet since it needs to rotate some.
Attached File  how_to_10.jpg   840.06KB   1065 downloads
The end should like about like this.
Attached File  how_to_11.jpg   290.38KB   1101 downloads
#4 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 05:44 AM
Cut the end of the top strips at an angle. About 30 degrees.
Attached File  how_to_12.jpg   306.62KB   676 downloads
Now start wrapping the lower strips around the handle with them lined up right next to each other. Try to keep them a little snug, but too snug. It'll take some practice to find the right bit of snugness.
Attached File  how_to_13.jpg   435.63KB   1184 downloads
When you get to the end use tacks to tack the ends of the strips to the dowel. Make sure you push the tacks in really well.
Attached File  how_to_14.jpg   241.69KB   1317 downloads
Now take the curved forceps and go under a wrapped strip, grab the end of a top strip and pull it through.
Attached File  how_to_15.jpg   1.01MB   1572 downloads
Keep going all the way down the handle making sure your braid lines are running straight.
Attached File  how_to_16.jpg   618.47KB   1459 downloads
Edited by Drac, 18 January 2008 - 06:07 AM.
#5 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 05:54 AM
When you get to the end nail 'em down with the " x 19 nails, trim the excess, and finish setting the nails at the other end so both ends look like this.
Attached File  how_to_17.jpg   796.16KB   708 downloads
Now take a bit of the leather you're using for your tails and cut a strip that's as long as your tail section will be wide and 1" or 1 1/8" wide. Use 1' for thicker, heavier leather and 1 1/8" for lighter leather (suede, deer tanned, deer, etc). use this chart for figuring your tail section. W = tail width, X = number of tails, plus ".My usual is 25 tails that are " wide, so I have " x 25 + " = 13". (WxX+"=T)
Attached File  how_to_18.jpg   261.4KB   681 downloads
Now attach the strip to one end of the handle (I use gel super glue) and wrap it around making sure it's lined up with the end.
Attached File  how_to_19.jpg   482.65KB   523 downloads
#6 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 06:02 AM
I use more super glue to stick the end in place until it's stapled down.
Attached File  how_to_20.jpg   581.79KB   285 downloads
Now use the pneumatic stapler to attach the leather. 2 at the end, then 3 more around the handle at 3, 6, and 9 (think of a clock with the first 2 being 12 when looking at the handle from the end).
Attached File  how_to_21.jpg   328.07KB   359 downloads
Now glue a piece of scrap of the same leather as the tails to the end. I use Leather Weld for this bit.
Attached File  how_to_22.jpg   327.68KB   456 downloads
When the glue's dry trim it down with either the leather shears (easier for us lefties) or the exacto knife
Attached File  how_to_23.jpg   374.03KB   446 downloads
#7 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 06:05 AM
Turkshead! I'll let you decide what kind you want to use. Mine are always this one (the only one I figured out) and are made using 3/16" beveled lacing and the end is super glued when finished and tucked.
Attached File  how_to_24.jpg   1.04MB   915 downloads
Now cut your tail blank. (W = tail width, X = number of tails, plus ". My usual is 25 tails that are " wide, so I have " x 25 + " = 13". (WxX+"=T)). for length whatever length you want plus 1". my tails are 20" long so my blank is 21" on the long side and 13" on the short. Take a scratch awl or pen and mark a line 1" from one of the short edges. For darker leathers I use the silver ink pen, for lighter leathers the black ink pen, and for suedes the scratch awl. You can see the line I made on this piece.
Attached File  how_to_25.jpg   621.03KB   663 downloads
#8 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 06:15 AM
Take the long straight edge and place it on the leather lengthwise, and use the metal ruler to measure your tail width. Cut towards the line to prevent stretch. Get close to the line but don't go past it.
Attached File  how_to_26.jpg   391.48KB   374 downloads
When you get to the end cut off that bit of excess. Now take the exacto and finish the cuts right to the line. This way you don't end up with strays when it's used.
Attached File  how_to_27.jpg   344.42KB   437 downloads
Make a line one inch from the end all the way around on the end opposite the Turkshead on the handle.
Attached File  how_to_28.jpg   1.02MB   416 downloads
Now attach the tails to the handle the same way the other end was done making sure the edge lines up with the line.
Attached File  how_to_29.jpg   1.14MB   350 downloads
Edited by Drac, 18 January 2008 - 06:16 AM.
#9 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 06:21 AM
Use the kite string to gather the tails tightly together about " from the ends at the base. 4 or 5 wraps is usually enough. pull is snug as you're wrapping it then tie a square knot.
Attached File  how_to_30.jpg   968.76KB   788 downloads
Do your Turkshead, remove the kite string, make sure you know how to use it and voila! Spankies all around!
Attached File  how_to_31.jpg   740.14KB   1375 downloads
#10 leatheroo
leatheroo
    Ambassador
  • Ambassador
  • PipPipPipPip
  • 1,548 posts
  • Gender:Female
  • Interests:leathercraft of course!! love all things tech, love tattoos, motorbikes, dog obedience training...work as a medical scientist in neurology
  • Leatherwork Specialty:motorbike seats, leather masks
  • Interested in learning about:braiding
Posted 18 January 2008 - 07:14 AM
Drac, these are wonderful instructions and so clear, thank you for taking the time and effort to do this.
This is a very GENEROUS thing to do.
Many many thanks.
#11 wolvenstien
wolvenstien
    Leatherworker
  • PipPipPip
  • 994 posts
  • Gender:Male
  • Leatherwork Specialty:learning
  • Interested in learning about:Motorcycle Stuff, BDSM Stuff, Anything else that interests me
  • How did you find leatherworker.net?:Google search for something or other
Posted 18 January 2008 - 10:58 AM
Thank you Drac
"The miracle is not how two adults can create a child, the phenomenon is how quickly a child can create two adults." -- VYBE
Her: Hit Me
Him: Do you want me to use the knife?
Her: No, When you hit with a knife, that's STABBING!
#12 Chitin
Chitin
    Member
  • PipPip
  • 66 posts
  • Leatherwork Specialty:Punk/fetish fashion
Posted 18 January 2008 - 11:43 AM
Thank you Drac
This is a fantastic tutorial! If I may suggest one addendum to the design - why not use a thinner dowel and have the tail leather extend all the way down through the handle, then braid over that? This improves durability, balance, and makes the handle a little bit soft so that it's easier to the grip.
#13 howardb
howardb
    Member
  • PipPip
  • 477 posts
  • Gender:Male
  • Interests:cooking, photography, and leather carving.
  • Leatherwork Specialty:Beginner, but improving
  • Interested in learning about:Darn near everything
  • How did you find leatherworker.net?:Tripped across it whilst surfing for leather info
Posted 18 January 2008 - 01:11 PM
Drac,
Thank you! I'm knot much of a braider (hahahahaha), but some GREAT tips on toy making here. I will definitely be adding one of these to my list of things I can't show my mother in law.
Brent
Brent Howard
CALG,
HLG
#14 Drac
Drac
    RIP Drac
  • Ambassador
  • PipPipPip
  • 540 posts
  • Gender:Male
Posted 18 January 2008 - 01:31 PM
leatheroo
I figured if other professionals here were nice enough to show how they make some of their items, then I could too. making this stuff was me livelihood for a long time, but I'll still share (unlike most in me biz).
chitin
with the way I attach tails, no loss of durability. you can hang from me floggers. also, I've seen 'em done the way you're talking about and seen the handle break during a hard session. plus it's very hard to get a consistent handle size. I actually used to do them like that (never heard of any of mine breaking) and I'd used electrical tape to do a compressing wrap before doing the handle braid. another problem is when done like that you get a seam that runs down the handle. it's not that noticeable with softer leathers, but something like latigo definitely shows it. also I've noticed the balance tends to vary a lot from flogger to flogger when done that way. when done this way the balance point is about a 1/4" into the top turkshead out from the handle. but let's face it, balance doesn't really mean anything since there's so many different ways to hold a flogger. it's more about what feels right for an individual.
howard
I don't think of the the handle being braided until is done since I suck at round braiding anything more than 4 strands. that's why I came up with the way i do the handle braid. it's much quicker and easier. try it and you'll see what I mean. the only semi-difficult part of it is figuring out how snug to wrap and pull, and you figure that out fairly quickly. plus, an advantage to it is if you have to let go it for some reason it's not gonna unravel itself.
#15 Chitin
Chitin
    Member
  • PipPip
  • 66 posts
Posted 18 January 2008 - 02:58 PM
Interesting... I'd never thought of it that way! Thanks!
Also thanks for the supplier tip in the other thread, I'd been wondering that for a long time!
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
