Juki Pro 2000/ferdco Question
  • Please log in to reply
19 replies to this topic
#1 Dogface
Dogface
    Member
  • PipPip
  • 59 posts
  • Gender:Male
  • Interests:Western Leather mfg.
  • Leatherwork Specialty:Western Leather stuff
  • Interested in learning about:carving, airbrush
Posted 19 December 2012 - 12:41 AM
I've had this machine for at least ten years but just had it serviced recently. Now I have a problem with the stitches and can't figure out what's causing it. The top line looks great but the bobbin thread is always loose and has loops and snags here and there. I thought the top tension was too loose but some say the bobbing thread is too loose and I dunno how to tighten that.
Any ideas here....?
#2 RomanNose
RomanNose
    New Member
  • Pip
  • 1 posts
Posted 19 December 2012 - 01:27 AM
I have a love hate relationship with this machine. The last employee I taught how to use the machine had the same problem. The bobbin was placed in backwards, and once we switched that around the problem was solved. Give it a try. Do you have the manual for that machine? It is well worth buying.
#3 Anne Bonnys Locker
Anne Bonnys Locker
    Leatherworker
  • PipPipPip
  • 602 posts
  • Gender:Male
  • Interests:Weird and wonderful sewing machines
  • Leatherwork Specialty:sewing machines
  • Interested in learning about:leather sewing
  • How did you find leatherworker.net?:seraching for my sewing machine
Posted 19 December 2012 - 02:26 AM
Why is it I hear of so many people having a problem only after the machine is "serviced?
Darren Brosowski
#4 Dogface
Dogface
    Member
  • PipPip
  • 59 posts
  • Gender:Male
Posted 19 December 2012 - 10:22 AM
Thanks for the replies. Yes I do have a manual and will check it for sure....especially the bobbin part. Is there any way to increase bobbin thread tension ?
#5 CowboyBob
CowboyBob
    Sewing Machine Dealer
  • PipPipPipPip
  • 1,517 posts
  • Gender:Male
  • Interests:We sell New & Used
    Leather Sewing Machines
    Parts,Needles &Thread
  • Leatherwork Specialty:Can help w/sewing machine questions & supplies
  • Interested in learning about:People needing help with machines
Posted 19 December 2012 - 10:46 AM
Looping on the bottom is the top thread.Either it isn't threaded correctly or it's to loose,make sure your going around the second tension on the side 1/1/2 x
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#6 Wizcrafts
Wizcrafts
    Leatherworker.net Regular
  • PipPipPipPip
  • 3,174 posts
  • Gender:Male
  • Interests:Leathercraft, contract sewing, Country-Western music, computer consulting and PC and website security and freelance Webmaster for hire.
  • Leatherwork Specialty:Belts, custom holsters, knife sheaths, guitar straps, rifle slings, custom vests, pouches/cases, wallets/purses, weight lifting belts, contract sewing
  • How did you find leatherworker.net?:Google search
Posted 19 December 2012 - 11:03 AM
There is a spring on the opening side of the pop open bobbin case. The bobbin thread goes backwards through a slit in the case, then under the opening in the spring and out. The spring is secured and adjusted by a screw on one end. There may also be a set screw inside a hole, just forward of the adjuster screw. You would have to loosen the stop screw to adjust the tension screw, then tighten it back to keep the tension from changing on its own.
I usually leave my stop screw just finger tight, so I can still change the bobbin tension screw as needed. I change thread sizes every day, so locking down the bobbin tension screw is more of a hassle than a benefit. The lock screw is more useful to folks who use just one size and brand of thread in the bobbin.
Posted IMHO, by Wiz
Cowboy CB4500, Singer 139w109, Singer 29k172, Singer 29k71, Singer 31-15, Singer 42-5, Fortuna power skiver, Consew portable blindstitch machine, Pfaff 4 thread, 2 needle serger, and various old iron body Singer straight stitch portable machines (including a 1902 Model 27).
#7 Dogface
Dogface
    Member
  • PipPip
  • 59 posts
  • Gender:Male
Posted 19 December 2012 - 11:04 AM
Bob,
That's what I thought too. My wife, who is a seamstress, said it's the bobbin tension. I have the top thread on correctly...checked it many times...
#8 CowboyBob
CowboyBob
  • PipPipPipPip
  • 1,517 posts
  • Gender:Male
Posted 19 December 2012 - 11:13 AM
Have you tried to tighten the top tension any yet?
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#9 Dogface
Dogface
    Member
  • PipPip
  • 59 posts
  • Gender:Male
Posted 19 December 2012 - 12:03 PM
Yes, I did a bit. Only way I know to do that on my machine is to run the thread thru more holes in that silver stick that's on top....I guess one could do an extra wrap on that set of wheels just below the take up gizmo on the end...
I still need to install that servo motor too...when sewing around complex curved it's hard to stay slow with the original system..I have to stop sometimes and that's when I get most of the loose loops on the bottom...
Edited by Dogface, 19 December 2012 - 12:05 PM.
#10 Trox
Trox
  • PipPipPipPip
  • 1,290 posts
  • Gender:Male
  • Interests:Dogs,Boats,fly Fishing, Industrial sewing machines, leather tools And Volvo Veterancars
  • Interested in learning about:When I stop learning, I am dead
Posted 19 December 2012 - 12:27 PM
When a mechanic do a service he/she has to sew the machine off, it is not enough to statically adjust the timing and other settings. I see that many have problems with machines after having them serviced, I would not pay for a job half done. I first seems like the bobbin tension is wrong, however it might be other reasons for this too.
My Pfaff machine acted just like you described it, some stitches was OK and other had loose loops on the bobbin side. The reason for this was wrong needle hook timing. Call the mechanic and complain, it should not be like this.
Trox
#11 Dogface
Dogface
    Member
  • PipPip
  • 59 posts
  • Gender:Male
Posted 19 December 2012 - 12:35 PM
Trox,
Thanks for that. I really would like to take it back to the shop that did the service but the darn thing is so heavy and it's upstairs in my shop above the garage. Just so hard to move... I will at least call them and try to talk to the tech that did the work. I really never asked them to adjust much, just clean and oil..all I wanted cuz it worked very well before this. Pretty sure I have the correct needles...
#12 CowboyBob
CowboyBob
  • PipPipPipPip
  • 1,517 posts
  • Gender:Male
Posted 19 December 2012 - 12:36 PM
For the tension to work properly it needs to be around the one you mentioned on the side 1& 1/2x or else it'll do just what you say it's doing.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#13 Dogface
Dogface
    Member
  • PipPip
  • 59 posts
  • Gender:Male
Posted 19 December 2012 - 12:43 PM
Yes, I know that and it is wound that way.. at least you agree that it's the top tension that's the problem...
#14 Sylvia
Sylvia
  • PipPipPipPip
  • 1,855 posts
  • Gender:Not Telling
Posted 19 December 2012 - 01:19 PM
I sure wish people would remember the mantra. Loops on bottom, top tension.... loops on top, bottom tension. (though a lot of the time it just needs the top tension loosened)
A backwards bobbin will hose you up. I've had industrial machine people tell me it doesn't matter.... but I have news for those folks.... It does matter. While most manuals won't say "thread must unspool from the bobbin to the left." if you look carefully at the pictures.... it will be clear which way it should unspool.
It sounds to me as if you don't have the top threaded properly.
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
#15 Dogface
Dogface
    Member
  • PipPip
  • 59 posts
  • Gender:Male
Posted 19 December 2012 - 02:49 PM
Just went up to check how it's threaded. Looks perfect to me. The loops I was/am getting are when I'm sewing 2oz lining onto 8/9 oz product. Lining was glued on with Barges first. My wonderment is if I didn't let the glue dry/set long enough. I just tried some scraps of the same wt. leather pieces without glue and the stitch line looks fine...
Whadda all think here ?
Edit: Just looked at the bobbin and it was put in the wrong way... We shall see. Top tension seems OK and is done the way Bob's video shows it...
Also had to change the size of the needle to fit thread sizes...was too big..
Edited by Dogface, 19 December 2012 - 03:57 PM.
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
